Rank based on values in 2 colums
ssj011
Good Day,
Need the formula to rank the data based on the 2 columns
  1. Rank should be for a combination of values in 2 different columns
  2. Rank should be ascending order till the value in the D is not changed
  3. If the value in the D column changes the rank should start again from 1
Sachin
Excel Wizard
Please try at
F1
=IF(D2=D1,IF(E2=E1,"",LOOKUP(9^9,F$1:F1)+1),1)
or MS365 Spill Array
=LET(a,D2:E86,b,UNIQUE(a),c,INDEX(a,,1)&INDEX(a,,2),
d,SEQUENCE(ROWS(b))-MATCH(INDEX(b,,1),INDEX(b,,1),)+1,
IF(MATCH(c,c,)=SEQUENCE(ROWS(a)),XLOOKUP(c,INDEX(b,,1)&INDEX(b,,2),d),""))
74159
