Put a string or row of numbers in order, no duplicates
dwrowe001
Hello everyone,
If I may ask to pick your brains.. I would like to take a string of numbers in a row, column H to AJ on sheet 1, the row contains random numbers between 1 to 45, and has duplicate numbers. the current order is haphazard, no order.. and there is the occasional blank or empty cell here and there, totally random. I would like to take all those numbers in the row, columns H to AJ and have them copied to a different sheet, say sheet 2 and put the numbers in numerical order, low to high, and remove all duplicate numbers.
If at all possible I would like an Exel formula. I can deal with formulas, I'm no expert but if I see a formula I can usually figure it out... usually.. I just can't come up with complex ones from scratch on my own.. and forget VBA or macros... I can't figure those out at all...
I appreciate your help with this.
Chief Ace
I would recommend creating a sample file and attach it so that people can work on it and help you in a timely manner.
Fluff13
If you have the dynamic array functions, how about
=SORT(UNIQUE(FILTER(Sheet1!H2:AJ2,Sheet1!H2:AJ2<>"")),,,1)
dwrowe001
Hi Fluff13, I tried entering the above formula into cell E3 on Sheet2, then Cntrl-Shift-enter to make it array, but it said it was invalid??
shrivallabha
If UNIQUE function is available to you then you can use below approach.
=IFERROR(SMALL(UNIQUE(("0"&Sheet1!$H2:$AK2)+0,TRUE,FALSE),COLUMNS($A$1:A$1)),"")
I have just tested against posted sample. See attached file. Depending on your version you may have to use CSE.
dwrowe001
shrivallabha,
I tried your formula and It does nothing, no errors though?? I'm using MS Office Home Student 2016. What is CSE?
bosco_yip
Try,
In "Sheet2" E4, copied across right :
=IFERROR(AGGREGATE(15,6,Sheet1!$H$2:$AK$2/(COUNTIF($D4:D4,Sheet1!$H$2:$AK$2)=0),1),"")
71168
