Problem with exponentiation in VBA...
ErikG
This is one of those situations where I'm missing something really simple/fundamental and I will/should feel embarrassed when I get some help, but here goes...
I started having some trouble using the exponentiation operator "*" in VBA. The errors usually say that an end of statement is expected. So I created a simple UDF to illustrate my problem. The UDF just raises a given number to a given power or raises a given number to the second power. It looks something like this:
Public Function EXPO(a As Double) As Double
    Dim b As Double
    b = 2#
    EXPO = a^b
End Function
OR
Public Function EXPO(a As Double, b As Double) As Double
    EXPO = a^b
End Function
701317013270134
The errors I am getting back are Compile errors (either Expected: end of statement or Expected: )). I'm can't find examples of the exponentiation operator that are any more complex than "x = a^b". What am I missing? Many thanks in advance for your help!
ErikG
Apologies. I somehow got this into Dashboards when I should have put it into Excel Macros!
Debaser
You just need spaces:
    Dim b As Double
    b = 2#
    EXPO = a ^ b
End Function
