Power Query - Source folder path changed not working
SbusyCR
I changed the path of the source folder and I am getting an error.
Original path: ...........Excel start up\Get and Transform (aka Power Query)\Test import files PQ
Actual path: ................Excel start up\Get and Transform (aka Power Query)\Test path change
File attached.
Thanks for your help!
Chihiro
You need to change it in more than one location for Query using Binary combine.
1. Sample File
2. Transform Sample File
3. Test import files PQ
If this type of folder change can occur relatively frequently. Then I'd recommend setting up parameter. Which is then used to replace all references to folders.
