    Hi Guest,
    Yours,
    Chandoo
  2. Hi All
Power BI Date Ranges
Discussion in 'Power Pivot, Power Map etc' started by msquared99, Nov 13, 2017.
  1. msquared99
    msquared99 Member
    174
    I have a table called SInvoices that has a column called invoiceDate. I am using a slicer to select a date range. I have another table called Commissions that has a column called startDate and another called endDate. I would like to have it when the slicer is used to select the date range it will populate the Commissions startDate and endDate columns with the date range that was selected.
    Is this possible?
  2. Chihiro
    Chihiro Excel Ninja
    4,656
    Not without flattening table. You can't use 2 date columns on same table as related column. It causes error in relationship.
    One way to get around it, is to consolidate start date and end date into single column with another column serving as flag column (Start/End). This way, you only have single date column which can be related via date dimension table.
  3. msquared99
    msquared99 Member
    174
    Just thinking here... what if I created two columns in the table SInvoices called startDate and endDate then using an IF statement, based on the SInvoice dates, I could calculate the commission rate and then use the slicer?
  4. Chihiro
    Chihiro Excel Ninja
    4,656
    Nope. Slicer must be based on single column and should not have looping/ambiguous relationship.
    I'd recommend either using flat structure or designing star schema with single fact table. See link for guide on how to build star schema.
    https://businessintelligist.com/201...n-power-bi-and-power-pivot-using-power-query/
    You could design star schema with multiple fact tables, but you should take care that there's no loop in relationship or cascading many to many relationships.
  5. msquared99
    msquared99 Member
    174
    I figured out how to do this. I wrote SQL to do all the filtering, then simply pasted the SQL code in to Power BI. It works like a charm.
Share This Page
