possible to keep row hidden when filter cleared/used?
Ben Millen
Hi all, so on the form im making a row is hidden, that row is used to create new rows with the same properties
however whenever i apply or clear filters this row is unhidden
any way to stop that?
Luke M
Can you move the row somewhere outside of filtered area, and then have formatting/formulas copied from there to new rows?
Ben Millen
i like your thinking but that doesnt seem the best way to do it, several people will be using the form and i dont want anything that will cause questions or that they can mess up
NARAYANK991
Hi Ben ,
I don't understand what properties are present in the hidden row , which will not be present in added rows ; can you clarify ?
If at all you are using VBA to customize any row that is added , why should the properties be copied from a hidden row ? Can they not be coded in the VBA procedure itself ?
Ben Millen
Hi Narayan, just looked at this, doesnt seem right though, it inserts the row at the bottom and doesnt apply the rules
NARAYANK991
Hi Ben ,
Since you say it does not apply the rules , can you say how I can test this ?
I had checked it before uploading the file , and from what I could see it worked.
Ben Millen
thats great Narayan, thanks, it was copying the color from the header but i fixed that with ".Interior.Color = xlNone"
thanks for your help on this :)
