Mohammad Shafaat
Please help and edit VB Code to send the mail along with attachment and same paste on mail body also: thanks in advance.
Sub sendmail()
' sendmail Macro
Dim dte As Date
Dim mon As Integer
Dim yr As Integer
Dim mailcount As Integer
Dim filtercol As Integer
Dim Maildb As Object
Dim MailDoc As Object
Dim attachME As Object
Dim Session As Object
Dim EmbedObj1 As Object
Dim UserName As String
Dim MailDbName As String
Dim recipient As String
Dim ccRecipient As String
Dim bccRecipient As String
Dim subject As String
Dim finlsub As String
Dim stSignature As String
Dim addname As String
Dim bodytext As String
Dim Attachment1 As String
Dim Attachment2 As String
Dim FilName As String
dte = Date
mon = Month(dte)
yr = Year(dte)
Attachment2 = Range("F15").Value
Sheets("MAIL-ID").Activate
Range("AG2").Value = 0
mailcount = Range("AG14").Value
subject = Range("F2").Value
bodytext = Range("H2").Value & Chr(10) & Range("F7").Value & Chr(10) & Range("H3").Value & Chr(10) & Range("H4").Value & Chr(10) & Range("H5").Value & Chr(10)
addname = Range("F12").Value
If mon <= 12 Then GoTo validated 'Else If mon >= 12 Then GoTo exitsub
exitsub: If UCase(Environ$("USERDOMAIN")) <> "domain" Then MsgBox "This is not your copy of Filtermails " & Chr(10) & "You are an UNAUTHORISED USER ", vbCritical
Exit Sub
validated: If mailcount = 0 Then MsgBox "There are no recepients in your list.", vbCritical, "WHAT ARE YOU DOING?"
For x = 0 To (mailcount - 1)
Sheets("MAIL-ID").Select
Range("AG2").Value = x + 1
FilName = (Environ$("cpinfo")) & "\cpinfo.xls"
If Dir(FilName) <> "" Then
Kill FilName
filtercol = Range("G2").Value
Range("AG4").Select
Selection.Copy
Range("AG7").Select
:=False, Transpose:=False
recipient = Range("AG7").Value
Range("AG5").Select
Selection.Copy
Range("AG8").Select
ccRecipient = Range("AG8").Value
If ccRecipient = "0" Then
ccRecipient = ""
Range("AG6").Select
Selection.Copy
Range("AG9").Select
bccRecipient = Range("AG9").Value
If bccRecipient = "0" Then
bccRecipient = ""
Range("AG3").Select
Selection.Copy
Range("AG11").Select
Range("AG11").Copy (Sheets("DATA").Range("O60000"))
Sheets("DATA").Select
If addname = "YES" Then
finlsub = subject & " ( " & Range("O60000").Value & " )"
finlbody = "Dear " & Range("O60000").Value & Chr(10) & Chr(10) & bodytext
If addname = "NO" Then
finlsub = subject
finlbody = bodytext
Range("A1").Select
If Range("a1") = "" Then
MsgBox "NO or Wrong arrangement of Data in DATA Sheet", vbCritical
Exit For
Selection.AutoFilter
Selection.AutoFilter field:=filtercol, Criteria1:= _
Range("A1").Select
Range(Selection, Selection.End(xlToRight)).Select
Selection.Copy
Workbooks.Add
ActiveSheet.Paste
Cells.Select
Cells.EntireColumn.AutoFit
ActiveWorkbook.SaveAs Filename:="C:\Users\Desktop\Extra\Data.xls", FileFormat:= _
xlNormal, Password:="", WriteResPassword:="", ReadOnlyRecommended:=False _
, CreateBackup:=False
ActiveWorkbook.Close
Dim OlApp As New Outlook.Application
Dim myNameSp As Outlook.Namespace
Dim myInbox As Outlook.MAPIFolder
Dim myExplorer As Outlook.Explorer
Dim NewMail As Outlook.MailItem
Dim OutOpen As Boolean
OutOpen = True
Set myExplorer = OlApp.ActiveExplorer
If TypeName(myExplorer) = "Nothing" Then
OutOpen = False
Set myNameSp = OlApp.GetNamespace("MAPI")
Set myInbox = myNameSp.GetDefaultFolder(olFolderInbox)
Set myExplorer = myInbox.GetExplorer
'myExplorer.Display ' You don't have to show Outlook to use it
' Create a new mail message item.
Set NewMail = OlApp.CreateItem(olMailItem)
With NewMail
'.Display ' You don't have to show the e-mail to send it
.To = recipient
.CC = ccRecipient
.BCC = bccRecipient
.subject = finlsub
.body = finlbody & vbCrLf & vbCrLf & stSignature
.Attachments.Add ("C:\Users\Desktop\Extra\Data.xls")
NewMail.Send
If Not OutOpen Then OlApp.Quit
'Release memory.
Set OlApp = Nothing
Set myNameSp = Nothing
Set myInbox = Nothing
Set myExplorer = Nothing
Set NewMail = Nothing
recipient = ""
ccRecipient = ""
bccRecipient = ""
finlsub = ""
FilName = ""
'finlsub = Null
finlbody = Null
Range("A1").Select
MsgBox "Thank you for using this MACRO"
