Percent format in input box
Thomas Kuriakose
Respected Sirs,
We have a requirement to use goal seek using vba to arrive at the percent change based on input value and final value. Kindly find attached a sample sheet where the details are entered.
Cell E4 is the set cell
Cell C5 is the changing cell
When we enter the value in the input box as % or decimal value, it is not correctly calculating. How can we input a value of 0.05, 0.10 etc. or 5%, 10% etc. in the input box to get the result..
The code entered is as follows -
Sub GoalSeekVBA()
Dim Target As Long
On Error GoTo Errorhandler
Target = InputBox("Enter the required value", "Enter Value")
Worksheets("Sheet1").Activate
With ActiveSheet
.Range("E4").GoalSeek Goal:=Target, ChangingCell:=Range("C5")
Exit Sub
Errorhandler:
MsgBox ("Sorry, value is not valid.")
Thank you very much for your support always,
with regards,
thomas
  • Input value GS.xlsm
Hi Thomas !​
As an input box returns a String but your variable is Long (and 5% aka 0.05 can't be a Long type !)
so an error raises as you can check yourself without any error handler (useless here !) …​
As it returns an empty string if cancelled the only type variable is Variant combined with the Evaluate method​
whatever if the entry is "5%" or any decimal value …​
So without any error handler :​
    Dim V
        V = Evaluate(InputBox("Enter the required value", "Enter Value"))
        If IsError(V) Then Exit Sub
Hi Thomas !​
    Dim V
Respected Sir,
Thank you so much for the great insight for this query.
This worked perfectly.
Thanks once again,
with regards,
thomas
