B bines53 Active Member May 9, 2016 #1 Hello friends, I want to share with you, EXCEL ADD IN, language C ++, functions XlOffset, XlToday are not volatile like Excel, do not know if it is the same as Excel. David
Marc L Excel Ninja May 9, 2016 #2 Hi ! Bad link ! Can you check your link after re-post it, thanks …
B bines53 Active Member May 9, 2016 #3 Hi Marc L, I see that there is a problem with the link, the solution is to copy it https://tkljh.s3.amazonaws.com/quant/tools/excel.html David
B bines53 Active Member May 9, 2016 #5 XlSelect ,As the INDEX function, but more flexible, =XlSelect($B1:B10,{1,3}) To do it with INDEX , it's more complicated =INDEX($B1:B10,{1,3}) David
