    Hi Guest,
    Yours,
    Chandoo
  2. Hi All
Newbie and help required
Discussion in 'VBA Macros' started by Beattima, Jun 12, 2018.
  1. Beattima
    Beattima New Member
    4
    Hi all looking for some help with my sheets, I have 2 sheets , Sheet 1 is the Task List where I need to put a tick in column "A" then this transfers the row to "Site Schedule tab"". I also want to be able to remove the tick from sheet 1 in case i make a mistake and this removes the data from the "Site Schedule tab only " I hope this all makes sense.I will have over 3000 task to add to the sheet as well.As you can see Ive managed to put ticks into Column A on the Task List but cant sus to pull this info through. Kind regards
  2. Marc L
    Marc L Excel Ninja
    4,258
    Hi !
    First there is an issue if you select the cell A1 in Task List worksheet
    so you must first mod the worksheet event code …
    In a second time it can be a mess to operate each time you select a cell in
    column A (or it needs a helper column in the Site Shedule worksheet)
    as it is easier to launch a procedure via a button
    or when you activate the Site Shedule worksheet (needs only 2 codelines)
  3. Belleke
    Belleke Active Member
    507
    Something like this?
    See attached.
    Thomas Kuriakose and Beattima like this.
  4. Beattima
    Beattima New Member
    4
    Thank you Marc and Belleke for your time and response in helping me out. I was searching for a solution late last night and found this Example see attached that would help me out. But Im struggling to work out why I can not get it past row 18 when I add more Tasks, but I like the Idea tick sheet 1 copies over to sheet 2 untick sheet 1 this removes from sheet 2. Belleke I like your idea as well though. Is there anyway i can use the example to work on my current spreadsheet?
  5. Marc L
    Marc L Excel Ninja
    4,258
    According to your initial sample,
    the mod for Task List worksheet event :​
    Code (vb):
        With Target
            If .Count = 1 And .Column = 1 And .Row > 1 Then
                If .Value = vbNullString Then
                   .Font.Name = "Marlett"
                   .Value = "a"
    You may Like it !
    Thomas Kuriakose likes this.
  6. Marc L
    Marc L Excel Ninja
    4,258
    According to your initial sample :
    • you must first correct the typo in cell W1 of Site Schedule worksheet
    (just compare / copy from source data worksheet
    as with a typo the code execution raises an error …)
    paste this code event to the Site Schedule worksheet module :​
    Code (vb):
    Private Sub Worksheet_Activate()
        [CA1:CA2].Value = [{"Tasks Required";"a"}]
        Sheet1.Cells(1).CurrentRegion.AdvancedFilter xlFilterCopy, [CA1:CA2], Cells(1).CurrentRegion.Rows(1)
Share This Page
