Need VBA for Partial Match Multiple Results
azumi
Hi guys need help here for a vba or udf that can pull data in partial text, for clearly explanation please take a look at the file
thank you in advanced
Azumi
  • Book1.xlsx
Hi, according to your attachment, a beginner starter event demonstration you must paste to the (Sheet1) worksheet module :​
        Dim L&, R&, S$(), V
    If Target.Address = "$A$8" Then
            L = 11
            Cells(L, 1).CurrentRegion.Clear
        If Not IsEmpty(Target) Then
        With [A1].CurrentRegion.Rows
            For R = 2 To .Count
                    S = Split(.Item(R).Cells(2).Text, "; ")
                    V = Application.Match("*" & Target.Text & "*", S, 0)
                If IsNumeric(V) Then
                   .Item(R).Copy Cells(L, 1)
                    Cells(L, 2).Value2 = S(V - 1)
                    L = L + 1
Awesome dude, thank you again, maybe i start learning VBA code soon as possible
Humble to your knowledge Marc
