Need help with sumif cells containing both text and number
kirkmaciano
Hi all
I am facing a sumifs problem.
A​
B​
C​
D​
E​
F​
G​
H​
I​
J​
1​
4​
4​
4​
4​
5​
5​
5​
5​
5​
2​
27 Apr​
28 Apr​
29 Apr​
30 Apr​
1 May​
2 May​
3 May​
4 May​
5 May​
3​
Person A​
4​
Person B​
F12​
F25​
5​
Person C​
H​
H​
H​
6​
Person D​
H5​
7​
Person E​
8​
Person F​
F30​
F30​
F30​
9​
Person G​
F​
F​
F​
10​
Person H​
11​
Person I​
The outcome I want is Person B returns 37, Person D returns 5, Person F returns 30 under April, and Person F returns 60 under May.
I managed to
i) =SUM(VALUE(RIGHT($B$3:$J$3,LEN(B3:J3)-1))) to sum only the numbers in a row
ii) =SUMIFS(XLOOKUP(lookup_value,$A$3:$A$11,$B$3:$J$11),$B$1:$J$1,MONTH(one of the cells showing a date)) to find the correct row and columns
But I am lost how to sumifs only the numbers after finding the correct row and columns.
Can any experts help me out?
Hi Hui
Thanks for the response. I have attached a file.
If I select Mabel at B19, I would like to see 60 (sum of the numbers from C10:M10 where name is Mabel) at C19 (April) and 60 at D19 (May).
Similarly if I select Mary, I would like to see 30 under April and 30 under May.
The rest of the names should return 0 since there are no numbers in the cells C4:M14.
  • ForChandooForum.xlsx
Here is a possible Power Query solution for you. Note that the presentation is different from what you asked.
let
    #"Unpivoted Other Columns" = Table.UnpivotOtherColumns(Source, {"Column1"}, "Attribute", "Value"),
    #"Split Column by Character Transition" = Table.SplitColumn(#"Unpivoted Other Columns", "Value", Splitter.SplitTextByCharacterTransition((c) => not List.Contains({"0".."9"}, c), {"0".."9"}), {"Value.1", "Value.2"}),
    #"Changed Type" = Table.TransformColumnTypes(#"Split Column by Character Transition",{{"Attribute", type date}}),
    #"Extracted Month Name" = Table.TransformColumns(#"Changed Type", {{"Attribute", each Date.MonthName(_), type text}}),
    #"Changed Type1" = Table.TransformColumnTypes(#"Extracted Month Name",{{"Value.2", Int64.Type}}),
    #"Replaced Value" = Table.ReplaceValue(#"Changed Type1",null,0,Replacer.ReplaceValue,{"Value.2"}),
    #"Grouped Rows" = Table.Group(#"Replaced Value", {"Column1", "Attribute"}, {{"Total", each List.Sum([Value.2]), type nullable text}})
in
    #"Grouped Rows"
In C19, enter array formula then copied across right and down :
=SUM(IFERROR(($C$2:$M$2=MONTH(0+("1/"&C$18)))*($B$4:$B$14=$B19)*MID($C$4:$M$14,2,99),0))
Array formula to be confirmed in pressing "Ctrl"+"Shift"+"Enter" instead of just Enter.
78877
Hi to all!
Another option could be:
No CSE option:
=SUMPRODUCT(($B$4:$B$14=$B19)*(MONTH(1&C$18)=$C$2:$M$2),--(0&MID($C$4:$M$14,2,15)))
Blessings!
