Need Help With Random Population
ham123
Hi everyone, I need help with making a Random Population VBA.
For now, I have made an example based on a formula:
=INDEX(Lists!A2:A612, RANDBETWEEN(2, 612))
What I am trying to do is to randomly populate data from the 'Lists" Sheets based on the range specified. I am trying to populate this data to a certain range: ActiveSheets("F5:F500")
Any help is much appreciated! :)
Hui
Staff member
Ham123
Do you want to choose 495 of the 610 items from the first list ?
I'll assume items can';t repeat
I would add a helper column to the original data and simply have the formula =rand() in that column
Then in the destination use a formula to retrieve the n'th largest item from the list using the helper column as a lookup column
=index(Your list, match(large(helper column, rows(Data Range Start:Data Range Current cell)), helper column, 0))
If you attach a sample file we can show you how
