Need help with macro for changing worksheet name
John1975
Hi Folks,
I have a close to 300 Excel files in one folder, all these Excel file have worksheet with similar names
I need a macro to change or create a new worksheet name which need to unique (like 1,2,3,4,....300). Can anyone help
Keetoowah
Hi John1975,
try this code,
Sub RenameSheets()
    Dim MyPath As String, FilesInPath As String
    Dim MyFiles() As String, Fnum As Long
    Dim mybook As Workbook
    Dim CalcMode As Long
    Dim sh     As Worksheet
    Dim x      As Integer
    x = 1
    Dim ErrorYes As Boolean
    'Fill in the path\folder where the files are
    MyPath = "C:\Users\Keetoowah\Desktop\Forum\" 'Adapt your path
    'If there are no Excel files in the folder exit the sub
    FilesInPath = Dir(MyPath & "*.xl*")
    If FilesInPath = "" Then
        MsgBox "No files found"
        Exit Sub
    'Fill the array(myFiles)with the list of Excel files in the folder
    Fnum = 0
    Do While FilesInPath <> ""
        Fnum = Fnum + 1
        ReDim Preserve MyFiles(1 To Fnum)
        MyFiles(Fnum) = FilesInPath
        FilesInPath = Dir()
    Loop
    'Change ScreenUpdating, Calculation and EnableEvents
    With Application
        CalcMode = .Calculation
        .Calculation = xlCalculationManual
        .ScreenUpdating = False
        .EnableEvents = False
    'Loop through all files in the array(myFiles)
    If Fnum > 0 Then
        For Fnum = LBound(MyFiles) To UBound(MyFiles)
            Set mybook = Nothing
            Set mybook = Workbooks.Open(MyPath & MyFiles(Fnum))
            On Error GoTo 0
            If Not mybook Is Nothing Then
                'Change cell value(s) in one worksheet in mybook
                With mybook
                    For Each sh In ActiveWorkbook.Worksheets
                        sh.Name = x
                        x = x + 1
                    Next sh
                If Err.Number > 0 Then
                    ErrorYes = True
                    Err.Clear
                    'Close mybook without saving
                    mybook.Close savechanges:=False
                    'Save and close mybook
                    mybook.Close savechanges:=True
                On Error GoTo 0
                'Not possible to open the workbook
                ErrorYes = True
        Next Fnum
        x = x + 1
    If ErrorYes = True Then
        MsgBox "There are problems in one or more files, possible problem:" _
             & vbNewLine & "protected workbook/sheet or a sheet/range that not exist"
    'Restore ScreenUpdating, Calculation and EnableEvents
    With Application
        .ScreenUpdating = True
        .EnableEvents = True
        .Calculation = CalcMode
John1975
Thanks for your efforts in sending this code. However, I'm getting messages"
protected workbook/sheet or a sheet/range that not exist". What son need to ensure in my Excel file so that I do not get this message?
Keetoowah
Hi John1975,
I tested with some files with different extension (xls, xlsx, xlsm, xlsb) without problems. Have you checked if some of the sheets are renamed? I suggest you to test with few files in a different folder. Also you could change the line
x = 1
with
X = 1000
John1975
I checked it with few files. All my files had one sheet with sheet name as "sheet1". I was trying to change such sheet names to unique names
Keetoowah
Hi John1975,
I modified the code slightly, if all your files have a single sheet, the following should do the trick:
Sub RenameSheets2()
    'https://chandoo.org/forum/threads/need-help-with-macro-for-changing-worksheet-name.43033/
    Dim sh     As Worksheet
    Dim x      As Integer
    x = 1
        Exit Sub
    Fnum = 0
        Fnum = Fnum + 1
        FilesInPath = Dir()
    Loop
    With Application
    If Fnum > 0 Then
            On Error GoTo 0
                With mybook.Worksheets(1)
                    .Name = x
                x = x + 1
        Next Fnum
    With Application
