Need help with If,Then,results type formula
grashop
I am trying to write a formula to help with auditing material reports. We have chemical ranges set up with a minimum and maximum, then the actual result is entered in another column. When the result is entered I would like to have it show whether the result is in range or not. Example
Carbon Min .05% Max 1.2% Actual result .09% Accept or Reject
I have been trying If,then as well IF, AND but without any luck.
Thanks for your help!!
Grashop
try
=if(and(carbon>=min,carbon<=max),"In range","Out of range")
put the cell references in for min, max and carbon as appropriate
change >= to > as you require etc
Wow thanks that looks like it is going to work perfectly!! Thank you, Thank you!!!! Saved by the Ninja!!!
