Greetings experts,
I have this code and what it does is that it will open the file explorer and the user has to select another Excel file which has a userform that they want to use on the Excel file where they run this code.
However, when I press cancel on the file explorer, a "type mismatch" error will appear. I do not want the user to see this. If they press cancel on the file explorer, the error should not be shown.
Any help is much appreciated!
Sub OpenFile()
Dim sFileName As Variant
sFileName = Application.GetOpenFilename("Excel Files (*.xl*), *.xl*")
If sFileName <> False And Dir(sFileName, vbNormal) <> "" Then
Call ShowForm(sFileName)
Sub ShowForm(ByVal FilePath As String)
'Please add your error handlers
Application.Run "'" & FilePath & "'!ShowForm"
On Error GoTo ErrHandle
Exit Sub
ErrHandle:
MsgBox "You canceled the process!"
