need help regarding Excel
Tanu
Hi, I have huge datbase containing yearwise, countrywise, product and sub product wise sales unit volume data. I need to generate a report in excel which produce the following outcomes,
What are my top ten countries for each category of products?
What are my top unit volume movers and where? How to flag them??
Can anyone help me?
The best way is to generate a pivot table with country & products, Paste special to an empty cell & apply conditional formatting which will highlight the top achievers.
Tanu,
You can try out as explained by Srinidhi
Or
You can convert your data into a Data Table...
and apply your filters whereever applicable
HTH
~VijaySharma
Hi, Thank u very much for the reply. I have already arranged the data in pivot table and applied conditional formatting too. My manager does not seems to be happy with pivot table :( Is there any other efficient way?? I want to flag the growth rate like +30%, -30%
You can setup any combination of a Table with appropriate headings and row titles, but you will need to extract the data manually using Sumproduct, Index(Match()) or Sum(Offset()) functions depending on how your data is setup
Have a read of:
http://chandoo.org/wp/2009/11/10/excel-sumproduct-formula/
or
http://chandoo.org/wp/2008/11/19/vlookup-match-and-offset-explained-in-plain-english-spreadcheats/
Alternatively can you please post your data somewhere and include a list of requirements
