Need help on userform creating
Natsha
Hi all
I have to create an userform for productivity purpose... I have added form and labels and text box... Whatever I know but I dnt know how to code it..I referred videos but the code used were different and doesn't work for me... I have attached the excel sheet..
In sheet two j have mentioned the fields format.. after referring it you can delete it.
I also added an commons button for email..
After entering data In the form..I will click the email and it should send an mail in Outlook with the below format.
To: " I can add it
Cc: I can add it
Hi name,
Please find the productivity status for the day
" Productivity status shuld be here with a table or an snap
Signature..
Please help..I been struggling to do this..
Belleke
Like this?
fill the userform and push Submit.
The data will be added an the mailbody will be generated
Then add the email adresses and Pusch Mail
Natsha
"Belleke, post: 279393, member: 34886"]
Like this?
[/QUOTE]
It's was perfect thank you so much belleke...
Natsha
Glad to help and thanks for the feedback.:)
I also have an doubt how to change the font size for the email body msg It's looks small in,I need atleast 11 or 12 font size
strbody = "Hi," & "<br>" & _
"Please find the productivity status for the day" & "<br/><br>" & RangetoHTML(rng) & "<br/><br>" & "Kind regards," & "<br/>" & L_01.Caption
Natsha
strbody = "<div style=""font-size:16px"">" & _
"<p>Hi," & "</p>" & _
"<p>Please find the productivity status for the day</p>" & _
"<p>" & RangetoHTML(rng) & "</p>" & _
"<p>Kind regards,</p>" & _
"<p>" & L_01.Caption & "</p>" & _
"</div>"
I got this answer from another forum...
vletm
Natsha
As You've read well from
There are clear sentences about crossposting if someone will use that kind of ...
