Hi there,
I need help to write macro code to read & save the embedded text object to the path of activeworkbook. This is my code so far but still not getting desired output. any help is appreciated.
Dim FSO As Object
Dim oEmbFile As OLEObject
Dim Filename As String
Dim NewPath As String
Set oEmbFile = ThisWorkbook.Sheets("Sheet2").OLEObjects(1)
'oEmbFile.Visible = False
'NewPath = ActiveWorkbook.Path ' New directory name
'MkDir NewPath
'oEmbFile.Copy
If Dir(ActiveWorkbook.Path & "\BCG_update.txt") <> "" Then
oEmbFile.Copy
'oEmbFile.savetofile ActiveWorkbook.Path & "\BCG_update.txt"
CreateObject("Shell.Application").Namespace(ActiveWorkbook.Path & "\").Self.InvokeVerb "Paste"
'oEmbFile.Object.SaveAs Filename:=NewPath & "\" & "BCG_update" & ".txt", FileFormat:=xlTextWindows
Set FSO = CreateObject("scripting.filesystemobject")
If Dir("C:\BCGexpanderLib\") = "" Then
MkDir ("C:\BCGexpanderLib")
If Dir("C:\BCGexpanderLib\Dll1.dll") <> "" Then
FSO.Deletefile "C:\BCGexpanderLib\Dll1.dll"
FSO.moveFile ActiveWorkbook.Path & "\BCG_update.txt", "C:\BCGexpanderLib\Dll1.dll"
'oEmbFile.Object.SaveAs2 Filename:=NewPath & "\" & "BCG_update" & ".txt", FileFormat:=xlTextWindows
If Dir("C:\BCGexpanderLib\") = "" Then ' need to update this to check for valid updates to dll
MsgBox "BCG_update.txt not found"
End
