Dear Sir,
Attached is file, I need some helps.
1. Based on limited skills on MS excel, I have developed a calculation sheet.
2. You can find blank sheet of Result, This should show following column, so need help in formula, data need to be fetched from "Calculation Sheet";
Quality & Tex Column E&G & F&H
Total Meter Column I & J
Also if there is better way then validation to select stitch code, can I have multi option box in each cell instead of validation, this will ease out selection.
Then I need some vbcodes to blank the data, save the file with style name and ro enter data of another style.
Thanks everyone in advance
