Need Excel Formula to calculate % change when Base value is extremely small
Josiev
I have looked to check solution for my problem but could not find a good answer. Hoping to get solution with help from this source.
Below is a sample of what I mean. The Budget values come from our financial system which were loaded by FP&A team. However, many values that should have been zeroed out, were left with very small values. I typically use the ABS formula to calculate % change to achieve proper positive/negative results. Since the base value has extremely low value, it generated a long result, see below. I would like to find a way that generates blank or "n/a" results but I do not know how to insert this statement to the myriads of actual versus budget expense accounts where this formula needs to be applied. I have attached the excel workbook to show the formula I tried to use but to no avail.
75559
Any help is very much appreciated.
Josie
  • % Variance Calculation.xlsx
Thank you Hui...I kept the ABS formula to the end as there are values that need to have the right negative / positive % result but added your suggestion on D3<=0.001...that seems to work.
Josie
Another possibility I have toyed with in the past is to report positive and negative deviations as percentages of a different base value.
= (Budget-Actual) / (IF(Budget>Actual,Budget,Actual))
For small deviations the difference is barely perceptible but, in situations like this, the negative percentage change reported is limited to (100%).
[Note: My expression for MAX is cumbersome but that is because it is designed to work with arrays 'actual' and 'budget'.]
