Need assistance with vba code
gdraco123
I have the below vba code on my workbook, but I’m getting the below runtime error, please advice.
>>> use code - tags <<<
Sub CopyMyWorkSheet()
Dim sNm As String
sNm = "MyWorkSheet " & Format(DateAdd("m", 1, [E3].Value), "mm-dd-yy")
If Not WksExists(wsc.Name) Then  <  Run-time error 424; Object required…here
ThisWorkbook.Unprotected "Password”"
ActiveSheet.Copy
ActiveSheet.Name = sNm
ThisWorkbook.Protect”Password”
Else: Exit Sub
''///this code in a separate module  Function
Function WksExists(wksName As String) As Boolean
WksExists = CBool(Len(Worksheets(wksName).Name) > 0)
End Function
Add first the code tags in your initial post just using the Code option via the 3 dots menu.​
Your issue comes from a logic error as the object variable is empty and this codeline has no sense when this variable is not empty !​
My apologies, I’m a beginner and have no idea what you mean with, “Add first the code tags in your initial post just using the Code option via the 3 dots menu.
Thanks…
gdraco123
Everybody can always reread Forum Rules from
and those code - tags, can find from:
Hello p45cal,
Thank you so much for your response
Like I mentioned above I’m a beginner and I got the above vba code from a website. Not sure how to fix it, does it mean I have to Dim “wcs”?
Cheers,
I have a invoice workbook that runs monthly with running balances and tabs for each month. And I want to automate it a bit, I want to create a macro button that will copy the latest month tab and create the following month tab all within the same workbook. And at the same time avoid duplicates if the button is clicked more than once in error. Hope this helps. Thanks..
Cheers,
try changing:
ActiveSheet.Copy
which will create a new workbook, to:
ActiveSheet.Copy After:=Sheets(Sheets.count)
which will add a sheet to the same workbook as the rightmost sheet.
