    Hi Guest,
    Yours,
    Chandoo
  2. Hi All
Navigate between pages using option element
Discussion in 'VBA Macros' started by YasserKhalil, Sep 11, 2017.
  1. YasserKhalil
    YasserKhalil Well-Known Member
    1,000
    Hello everyone
    I am practicing on web scraping and I have this try to grab data from 57 pages .. I am trying to use option tags to navigate between pages ..
    The code only grabs the first page 57 times
    Code (vb):
    Sub Test()
        Dim xml As Object
        Dim html As Object
        Dim objTable As Object
        Dim result As String
        Dim lRow As Long
        Dim lngTable As Long
        Dim lngRow As Long
        Dim lngCol As Long
        Dim ActRw As Long
        Dim htmlOptions As MSHTML.IHTMLElementCollection
        Dim htmlOption As MSHTML.IHTMLElement
        Set xml = CreateObject("MSXML2.XMLHTTP.6.0")
        With xml
            .Open "GET", "http://registers.centralbank.ie/FundSearchResultsPage.aspx?searchEntity=FundServiceProvider&searchType=Name&searchText=&registers=6%2c29%2c44%2c45", False
            .send
        result = xml.responseText
        Set html = CreateObject("htmlfile")
        html.body.innerHTML = result
        Set htmlOptions = html.getElementsByTagName("option")
        For Each htmlOption In htmlOptions
            With htmlOption
                htmlOption.Click
                xml.Open "GET", "http://registers.centralbank.ie/FundSearchResultsPage.aspx?searchEntity=FundServiceProvider&searchType=Name&searchText=&registers=6%2c29%2c44%2c45", False
                xml.send
                Set objTable = html.getElementsByTagName("table")
                For lngTable = 1 To objTable.Length - 1
                    For lngRow = 1 To objTable(lngTable).Rows.Length - 2
                        For lngCol = 0 To objTable(lngTable).Rows(lngRow).Cells.Length - 1
                            ThisWorkbook.Sheets("Sheet1").Cells(ActRw + lngRow + 1, lngCol + 1) = objTable(lngTable).Rows(lngRow).Cells(lngCol).innerText
                        Next lngCol
                    Next lngRow
                    ActRw = ActRw + objTable(lngTable).Rows.Length + 1
                Next lngTable
        Next htmlOption
    Any help please
  2. Chihiro
    Chihiro Excel Ninja
    5,055
    Page is loaded by JavaScript. You can't scrape it like that using XML and HTTP.
    Looking at how site loads data, easiest method is to use IE automation or Selenium.
    You need navigate to URL, then wait for load. Then identify use getElementsByID on "ctl00_cphRegistersMasterPage_gvwSearchResults_ctl18_ddlPages".
    Then for each child object in that element, set selected to TRUE and and wait for load and loop.
    Scraping data during each iteration of the loop.
    Alternately, you can probably use click on "ctl00_cphRegistersMasterPage_gvwSearchResults_ctl18_btnNext" to loop.
    Chirag R Raval and shahin like this.
  3. YasserKhalil
    1,000
    Thanks a lot for reply. But why it is grabbing the first page ..
    Isn't there a way to use XML and HTTP to loop through the pages ..
    I tried to look at the URL but didn't find anu suitable part to change the page from ..
    And using IE will be slower
  4. Marc L
    Marc L Excel Ninja
    4,257
    Hi !
    When you manually load second page, just inspect the
    request used by your webbrowser (scrapping basics !) …
    Do the same for third page and compare both : you should catch it !
    shahin likes this.
  5. YasserKhalil
    1,000
    Thanks a lot Mr. Marc for reply
    Can you guide me with a link to learn how to inspect the request ..?
    In fact I have no idea about what do you mean exactly .. I have inspected the drop down but couldn't get a clue
    I have looped option elements and it gave me 57 numbers .. But the question is how to navigate using this xml method to the 57 pages?
  6. Marc L
    Marc L Excel Ninja
    4,257
    shahin likes this.
  7. Chihiro
    Chihiro Excel Ninja
    5,055
    It's going to be pain in the rear to scrape this site using XMLHttp.
    You can see where ddlPages is set at end of query string. However, this site uses viewstate and other properties that need to be included in query string.
    shahin likes this.
  8. YasserKhalil
    1,000
    Thanks a lot for replies ..and for these useful links
    So there is no way to do that using XML ?! or there is a way but will be difficult
    I still can't figure it out
  9. Chihiro
    Chihiro Excel Ninja
    5,055
    There is way. See the request string in the screen shot.
    You just need to parse that monster of string and just change the last parameter in each loop iteration.
    Chirag R Raval likes this.
  10. YasserKhalil
    1,000
    Thanks a lot for reply Chihiro .. Forgive me .. I don't know how you snapshot your screen shot and I couldn't find that monster string ..Can you guide me please?
  11. Chihiro
    Chihiro Excel Ninja
    5,055
    On your browser, go to Tool and locate Developer tools (Ctrl + SHIFT + I for chrome).
    Set it to record and retain and navigate to Netowrk tab. There locate "All".
    Now, navigate to site and observe what happens when you change page.
    You should see "FundSearchResultsPage.aspx....". Click on it.
    Now, on right hand panel, you will see "Headers" navigate down on that tab, find "Form Data" section.
    There you will see the request string "POST"ed to get the response. However, since it's been parsed, click on "view source" to get the raw string.
    Read through 1st and 2nd link provided by Marc and you should find more general tutorial on developer tool use.
    EDIT: Since, it's using POST method, you may need to set few headers play around with it and test what is required.
    YasserKhalil likes this.
  12. YasserKhalil
    1,000
    Thank you very much for great information. I will have a look at those links again to learn more. Thanks for guiding me
  13. YasserKhalil
    1,000
    Will I have to use this monster string in looping .. Is there any other escape way?
  14. Chihiro
    Chihiro Excel Ninja
    5,055
    Just store it as variable and use that variable in loop.
  15. YasserKhalil
    1,000
    Thanks a lot. Will it be inside the loop only in the place of url ..? or in both strings in the code
  16. Chihiro
    Chihiro Excel Ninja
    5,055
  17. YasserKhalil
    1,000
    Will I start with this string "__EVENTTARGET=" or any other string .. I am confused and don't know how will I split this monster string ..
  18. Marc L
    Marc L Excel Ninja
    4,257
    So the easier for you is to pilot IE …​
  19. YasserKhalil
    1,000
    Thanks .. But what about the speed point?
  20. Chihiro
    Chihiro Excel Ninja
    5,055
    With just 57 pages, it's way easier to use IE. Though it's slower, less hassle in coding.
    Now if it was 10k + pages. Then definitely spend time to code. Since, each load will take about 5 sec...
  21. shahin
    shahin Active Member
    899
    Hey, give this a shot. It will give you the names from the first page.
    Code (vb):
    Sub central_bank()
        Dim http As New XMLHTTP60, html As New HTMLDocument
        Dim ArgumentStr As String, post As Object
        ArgumentStr = "__EVENTTARGET=&__EVENTARGUMENT=&__LASTFOCUS=&__VIEWSTATE=%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" & _
        "ZXMgZmlybSBhdXRob3Jpc2F0aW9ucy4QFgNmAgECAhYDFCsABRYKHghSZWFkT25seWceCkhlYWRlclRleHQFB1JlZiBOby4eCURhdGFGaWVsZAUPUmVmZXJlbmNlTnVtYmVyHg5Tb3J0RXhwcmVzc2lvbgUPUmVmZXJlbmNlTnVtYmVyHgpGb290ZXJUZXh0BQNBU0MWBB4IQ3NzQ2xhc3MFCWd2d0NvbHVtbh4EXyFTQgICZGRkFCsABRYMHg1EYXRhVGV4dEZpZWxkBQROYW1lHwsFCUZpcm0gTmFtZR4VRGF0YU5hdmlnYXRlVXJsRmllbGRzFQEPUmVmZXJlbmNlTnVtYmVyHhtEYXRhTmF2aWdhdGVVcmxGb3JtYXRTdHJpbmcFPUZpcm1EYXRhUGFnZS5hc3B4P2Zpcm1SZWZlcmVuY2VOdW1iZXI9ezB9JnJlZ2lzdGVyPTYsMjksNDQs" & _
        "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" & _
        "ZXN1bHRzHxACgoAgZBYCZg9kFiICAQ9kFgZmDw8WAh8ABQdDMTU3MDA4ZGQCAQ9kFgJmDw8WBB8ABQ4xNyBDYXBpdGFsIExMUB4LTmF2aWdhdGVVcmwFQUZpcm1EYXRhUGFnZS5hc3B4P2Zpcm1SZWZlcmVuY2VOdW1iZXI9QzE1NzAwOCZyZWdpc3Rlcj02LDI5LDQ0LDQ1ZGQCAg8PFgIfAAUGJm5ic3A7ZGQCAg9kFgZmDw8WAh8ABQZDNTgxMjJkZAIBD2QWAmYPDxYEHwAFHTM2IFNvdXRoIENhcGl0YWwgQWR2aXNvcnMgTExQHxwFQEZpcm1EYXRhUGFnZS5hc3B4P2Zpcm1SZWZlcmVuY2VOdW1iZXI9QzU4MTIyJnJlZ2lzdGVyPTYsMjksNDQsNDVkZAICDw8WAh8ABR0zNiBTb3V0aCBDYXBpdGFsIEFkdmlzb3JzIExMUGRkAgMPZ" & _
        "BYGZg8PFgIfAAUGQzY4MjM4ZGQCAQ9kFgJmDw8WBB8ABS4zNiBTb3V0aCBJbnZlc3RtZW50IE1hbmFnZXJzIChJcmVsYW5kKSBMaW1pdGVkHxwFQEZpcm1EYXRhUGFnZS5hc3B4P2Zpcm1SZWZlcmVuY2VOdW1iZXI9QzY4MjM4JnJlZ2lzdGVyPTYsMjksNDQsNDVkZAICDw8WAh8ABS4zNiBTb3V0aCBJbnZlc3RtZW50IE1hbmFnZXJzIChJcmVsYW5kKSBMaW1pdGVkZGQCBA9kFgZmDw8WAh8ABQdDMTMyMTcyZGQCAQ9kFgJmDw8WBB8ABRIzaSBJbnZlc3RtZW50" & _
        "cyBwbGMfHAVBRmlybURhdGFQYWdlLmFzcHg%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%2FZmlybVJlZmVyZW5jZU51bWJlcj1DNDg0MzEmcmVnaXN0ZXI9NiwyOSw0NCw0NWRkAgIPDxYCHwAFE0FBT" & _
        "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" & _
        "TWFuYWdlbWVudCBMTEMfHAVBRmlybURhdGFQYWdlLmFzcHg%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" & _
        "IPDxYCHwAFBiZuYnNwO2RkAg8PZBYGZg8PFgIfAAUHQzE3MTY4MWRkAgEPZBYCZg8PFgQfAAUWQWJlcmZvcnRoIFBhcnRuZXJzIExMUB8cBUFGaXJtRGF0YVBhZ2UuYXNweD9maXJtUmVmZXJlbmNlTnVtYmVyPUMxNzE2ODEmcmVnaXN0ZXI9NiwyOSw0NCw0NWRkAgIPDxYCHwAFBiZuYnNwO2RkAhAPDxYCHgdWaXNpYmxlaGRkAhEPZBYCZg9kFggCAQ8PFgIeB0VuYWJsZWRoZGQCAw8PFgIfHmhkZAIFDxAPFgIfBmdkDx" & _
        "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" & _
        "Q2BQI0NmcQBQI0NwUCNDdnEAUCNDgFAjQ4ZxAFAjQ5BQI0OWcQBQI1MAUCNTBnEAUCNTEFAjUxZxAFAjUyBQI1MmcQBQI1MwUCNTNnEAUCNTQFAjU0ZxAFAjU1BQI1NWcQBQI1NgUCNTZnEAUCNTcFAjU3ZxYBZmQCBw8PFgIfAAUCNTdkZBgCBR5fX0NvbnRyb2xzUmVxdWlyZVBvc3RCYWNrS2V5X18WBAU8Y3RsMDAkY3BoUmVnaXN0ZXJzTWFzdGVyUGFnZSRndndTZWFyY2hSZXN1bHRzJGN0bDE4JGJ0bkZpcnN0BTtjdGwwMCRjcGhSZWdpc3RlcnNNYXN0ZXJQYWdlJGd2d1NlYXJjaFJlc3VsdHMkY3RsMTgkYnRuUHJldgU7Y3RsMDAkY3BoUmVnaXN0ZXJzTWFzdGVyUGFnZSRndndTZWFyY2hSZXN1bHRzJGN0bDE4JGJ0bk5leHQFO2N0bDAwJGNwaFJlZ2lzdGVyc01hc3RlclBhZ2UkZ3Z3U2VhcmNoUmVzdWx0cyRjdGwxOCRidG5MYXN0BS1jdGwwMCRjcGhSZWdpc3RlcnNNYXN0ZXJQYWdlJGd2d1NlYXJjaFJlc3VsdHMPPCsACgEIAjlkQ3RZxUBq4maQklzpY%2Fiz0lRdFTg%3D&__SCROLLPOSITIONX=0&__SCROLLPOSITIONY=540&__EVENTVALIDATION=%2FwEWQwLhyt7aAQKdmL%2BNBQLBvq75AwKEl773" & _
        "CgL%2B4cLqBQLR7%2FSRCgKrq7r4AgKnifiNCgKo5tLjBgKp5tLjBgKq5tLjBgKr5tLjBgKs5tLjBgKt5tLjBgKu5tLjBgK%2F5tLjBgKw5tLjBgKo5pLgBgKo5p7gBgKo5prgBgKo5qbgBgKo5qLgBgKo5q7gBgKo5qrgBgKo5rbgBgKo5vLjBgKo5v7jBgKp5pLgBgKp5p7gBgKp5prgBgKp5qbgBgKp5qLgBgKp5q7gBgKp5qrgBgKp5rbgBgKp5vLjBgKp5v7jBgKq5pLgBgKq5p7gBgKq5prgBgKq5qbgBgKq5qLgBgKq5q7gBgKq5qrgBgKq5rbgBgKq5vLjBgKq5v7jBgKr5pLgBgKr5p7gBgKr5prgBgKr5qbgBgKr5qLgBgKr5q7gBgKr5qrgBgKr5rbgBgKr5vLjBgKr5v7jBgKs5pLgBgKs5p7gBgKs5prgBgKs5qbgBgKs5qLgBgKs5q7gBgKs5qrgBgKs5rbgBgLg2MrQBwLk2LbQCBjiuH1rQsNKIEFR7v2fYvVvD8aB&ctl00%24cphRegistersMasterPage%24gvwSearchResults%24ctl18%24ddlPages=1&ctl00%24cphRegistersMasterPage%24gvwSearchResults%24ctl18%24btnNext.x=262&ctl00%24cphRegistersMasterPage%24gvwSearchResults%24ctl18%24btnNext.y=6"
        With http
            .Open "POST", "http://registers.centralbank.ie/FundSearchResultsPage.aspx?searchEntity=FundServiceProvider&searchType=Name&searchText=&registers=6%2c29%2c44%2c45&AspxAutoDetectCookieSupport=1", False
            .setRequestHeader "Content-type", "application/x-www-form-urlencoded"
            .send ArgumentStr
            html.body.innerHTML = .responseText
        For Each post In html.getElementsByClassName("entityNameColumn")
            With post.getElementsByTagName("a")
                If .Length Then x = x + 1: Cells(x, 1) = post.innerText
        Next post
    Thanks to sir Chihiro for showing me how to break such giant string into a manageable chunk.
  22. YasserKhalil
    1,000
    Thanks a lot Mr. Shahin.
    As for results I got just one column. It is supposed there are three columns
    And how can I loop .. I didn't find a clue for a page number
  23. shahin
    899
    Just tell me what you wanna get as results from its first page. I just tried to show that it works. Specify it clearly so that i can do it for you.
  24. shahin
    899
    Is this what you wanted?
    Code (vb):
    Sub central_bank()
        Dim tbl As Object, tRow As Object, tCel As Object
        With http
            .send ArgumentStr
        Set tbl = html.getElementsByTagName("table")(1)
        For Each tRow In tbl.getElementsByTagName("tr")
            For Each tCel In tRow.getElementsByTagName("td")
                If Not InStr(tCel.innerText, "Page") > 0 Then
                    c = c + 1: Cells(x + 1, c) = tCel.innerText
            Next tCel
            c = 0
            x = x + 1
        Next tRow
  25. YasserKhalil
    1,000
    That's great and awesome. Now how can be looped through the 57 pages? I looked at the string and didn't find a clue to page number
Share This Page
