My VBA works, but I keep getting an 'Object Required' error anyway
PipBoy808
Sub CreateCopy3()
    Set Workbook= ActiveWorkbook
    Sheets([{"Weekly Planning", "Contact Details"}]).Copy.Move
The above code copies the first two sheets of a workbook and places them in a brand new workbook. It works, but I keep getting a "Run-time 424: Object Required Error" on the last line nonetheless. This could be a problem as I want to place this sub within another one, and this error may cause the whole thing to break. Does anyone know what the error could refer to?
Certainly Excel is functioning well !
Do you wish to copy or to move ? You cannot have both.
And after you have copied , do you wish to save or .... ?
Creating a new subroutine with just two lines is not justified , especially if this procedure will not be called repeatedly. You might as well include these same two lines ( of course after correcting the .Copy.Move part ) in your main procedure.
Copy and then move the copies while leaving the originals, and it works! It copies those two worksheets and moves them to a new workbook. After I've copied I wish to save as a filepath. I actually have this in my code afterwards:
ThisWorkbook.SaveAs "C:\Myfilepath\Myfile.xls"
but I don't get that far because I get this error. Again, I'm not sure why I get the error, because the code copies and moves the sheets just fine.
Would something like this work better?
Then
  Sheets([{"Weekly Planning", "Contact Details"}]).Move
OK weird, I took out the word 'Move' and it works fine without the error. I didn't realise that 'Copy' would be sufficient on its own.
Ah wait, I have one more problem. How do I refer to the new workbook and SaveAs in VBA? Using ThisWorkbook.Saveas only saves the original workbook. I guess I have to activate the new workbook somehow maybe?
After you do the Copy, assuming you haven't specified a location within ThisWorkbook (like you were copyinig the worksheet within the same workbook), XL will automatically create a new workbook with those sheets, as you've seen so far. To refer to that workbook, it will be the ActiveWorkbook after the copy command.
