Yvonne Love
I'm getting more and more familiar with dynamic arrays formulas every day, and I am loving them! But what I haven't figured out how to do is use SUMIFS (or count/min/max, etc.) on a multi-column spilled range. For instance, I need to pull total hours for each company based on location. One company may have more than one location, and I used unique/filter/index to pull the unique company and location combinations. Now I need to sum the hours for each company/location combination, but since the spill range is two columns, I haven't be able to figure out how to do that and I haven't been able to find any blogs, videos, etc. that discuss that piece. I feel like it's something simple that I am just completely missing, but I wanted to ask the experts to see if anyone had any thoughts. I've attached sample data with 500 rows of data (and I used RANDARRAY to pull it!).
Alternatively, if this cannot be done, is there a way to pull two separate spill ranges using filter/unique, etc., where the company will spill as many times as there is a unique location (so could be only once or could be multiple times), and then the separate column pulling the unique location? I know I could use analysis formulas (sum, etc.) with two separate ones. I am just not thinking of the correct unique/filter arguments to pull the separate columns.
Thank you in advance for your assistance!
YL
YL
