Asbestos_Jen
Hello all! I'm relatively new to writing macros, mostly just recording or taking things from searches and modifying to (try to) fit my needs.
I'm using the code I found here at the link below, and have modified it and it almost does what I want.
I would like to change it to:
1. save the new file "report" to the directory the source file is in;
2. delete the default sheets created in the "report" file, without dialog boxes for each one (our system defaults to 3, I don't know if that's normal);
3. stop Excel from asking about "large amount of data on clipboard";
4. remove all named ranges from the Name Manage in the "report" file.
If these should all be separate threads, please let me know.
I would be grateful for any help!
Thanks!
Jen (sadly, still on Excel 2007)
Range of selected cells copy & paste with all formats except formula; Save in a specific Folder; Name as a Cell ValueHi All, I have a work book with different sheets. I want to select some cells of the active sheet then copy those data into a new excel file with font type, color of the fonts & column width formats except formula, finally new excel file would save in the folder "C:\Users\XXX\ABC" giving file...
chandoo.org
Sub Demo()
'modified from https://chandoo.org/forum/threads/range-of-selected-cells-copy-paste-with-all-formats-except-formula-save-in-a-specific-folder-name-as-a-cell-value.44527/post-265782
Dim wb As Workbook
Dim fName As String
Dim fPath As String: fPath = "C:\Users\REDACTED" 'CHANGE TO \current directory\ IN FINAL VERSION JD
Dim obj
OptimizeVBA True
Set wb = Workbooks.Add
With ThisWorkbook.Sheets("XLSTemp") 'changed sheetname JD
fName = .Range("Z8").Text 'changed range JD
.Copy , wb.Sheets(1)
With wb
Call DeleteRows 'delete rows that say "Delete"
.Sheets("Sheet1").Delete
.Sheets("Sheet2").Delete 'Added line JD
.Sheets("Sheet3").Delete 'Added line JD
.SaveAs fPath & fName & ".xlsx", 51
With .Sheets("XLSTemp") 'changed sheetname JD
.Range("U:AB").Delete 'changed range JD
.Range("A:T").Copy 'changed range JD
.Range("A1").PasteSpecial xlValues
For Each obj In .Shapes
obj.Delete
'Call ProtectSheet() goes here? JD
.Close True
OptimizeVBA False
Sub OptimizeVBA(isOn As Boolean)
Application.Calculation = IIf(isOn, xlCalculationManual, xlCalculationAutomatic)
Application.EnableEvents = Not (isOn)
Application.DisplayAlerts = Not (isOn)
Application.ScreenUpdating = Not (isOn)
Sub DeleteRows()
'Modified from:
'https://www.mrexcel.com/board/threads/vba-delete-rows-based-on-cell-value.1171142/post-5692643
'Joe4 MyDeleteMacro()
Dim lr As Long, lr2 As Long
' Find last row with data in column P (U in my case)
lr = Cells(Rows.Count, "U").End(xlUp).Row
' Hide all rows not equal to zero (Delete)
Columns("U:U").AutoFilter
ActiveSheet.Range("$U$1:$U$" & lr).AutoFilter Field:=1, Criteria1:="Delete"
' Find last row in column P with data after filter (U in my case)
lr2 = Cells(Rows.Count, "U").End(xlUp).Row
' Exit sub if no data to delete data (only header visible)
If lr2 = 2 Then Exit Sub
' Delete unhidden data
ActiveSheet.UsedRange.Offset(1, 0).Resize(ActiveSheet.UsedRange.Rows.Count - 1).Rows.Delete
' Remove filter
Range("U1").AutoFilter
Sub ProtectSheet()
Dim Ws As Worksheet
Set Ws = Worksheets("XLSTemp")
Ws.Protect Password:="MyPW"
Thanks!
