Hi all)
in this topic:
http://chandoo.org/forums/topic/automatting-tabulation-switching-between-worksheet-tabs-automatically
Hui wrote:
i noticed that when macro running you cant toggle between workbooks that loaded in one Excel instance.
i mean it is possible to toggle between workbooks if they loaded in different instances of Excel.
also it is possible to toggle between worksheets in active workbook during running macro.
so i cant understand why is that? why running macro blocking manual switching (using Alt+TAB or taskbar) to another workbook that loaded in same inctance of excel?
i think there is some mistake.
i mean if application is too busy and stop interracting with user - it should not allow switching between worksheets too. am i not right?
but it allows.. so i guess that it is not too busy.
and i guess it Can interract with user
so then Why is it not possible to switch between workbooks loaded in one instance of Excel?
what i need is excel vba script that can be running in background mode, minimized and creating no problems to user i.e. allow to open any other workbooks.
and i hope that i miss some little simple thing like some workbook's property or maybe macro's property that allows running macro in Modal/Modeless Mode.
please sorry my english
is my question clear?
i prepared test macro
its dumb but clear:
try switch to another workbook(in same Excel instance) while its running
in this topic:
Hui wrote:
I've never tried to do any Multitasking within Excel and having had a quick play, and it has a few idiosyncrasies.
If you run 1 instance of Excel and have 2 seperate workbooks open within it, only the active one will run a Macro. You can run the macro and change between workbooks, but only the active one is running.
However if you start a second instance of Excel you can load separate files in each and they will both run beside each other quite happily...
its dumb but clear:
Sub somebutton_Click()
Dim a As Range
Dim b As Range
Set a = Range("A1:AL100")
For Each b In a
DoEvents: DoEvents
b.Value = "test"
