Hello Everyone -
The following macro was working fine with Excel 2016. I now have Excel 365 but this macro doesn't work. Request your help please.
thanks,
Rohit
Sub Send_Formatted_Range_Data()
Dim oWorkSpace As Object, oUIDoc As Object
Dim rnBody As Range
Dim lnRetVal As Long
Dim Recepient As String
Dim subjectName As String
Dim LotusDB As String
Dim totalSender, currentSender, i As Integer
totalSender = Sheets("Launcher").Range("B5").Value
currentSender = Sheets("Launcher").Range("A5").Value
For i = currentSender To totalSender
Recepient = Sheets("Launcher").Range("A7").Value
LotusDB = Sheets("Launcher").Range("D7").Value
subjectName = Sheets("Launcher").Range("C7").Value
'Check if Lotus Notes is open or not.
lnRetVal = FindWindow("NOTES", vbNullString)
If lnRetVal = 0 Then
MsgBox "Please make sure that Lotus Notes is open!", vbExclamation
Exit Sub
'A named range in the activesheet is in use.
Sheets("Data").Select
ActiveSheet.Range("$A$9:$D$17").AutoFilter Field:=1, Criteria1:=Recepient 'Remember to change this
Set rnBody = ActiveSheet.Range("MailRange1")
rnBody.Copy
'Instantiate the Lotus Notes COM's objects.
Set oWorkSpace = CreateObject("Notes.NotesUIWorkspace")
'Set oUIDoc = oWorkSpace.ComposeDocument("", "C:\Users\********\Mail Merge\mail_merge.nsf", "Memo") 'Update this
Application.Wait (Now() + TimeValue("00:00:01"))
On Error GoTo 0
Set oUIDoc = oWorkSpace.CurrentDocument
'Using LotusScript to create the e-mail.
'Here the selected range is pasted into the body of the outgoing e-mail.
Call oUIDoc.GoToField("Body")
Call oUIDoc.Paste
'Call oUIDoc.FieldAppendText("EnterCopyTo", stCC)
Call oUIDoc.FieldAppendText("Subject", subjectName)
Call oUIDoc.FieldAppendText("EnterSendTo", Recepient)
'Save the created document.
Call oUIDoc.Save(True, False, False)
'If the e-mail also should be sent then add the following line.
Call oUIDoc.Send(True)
'Release objects from memory.
Set oWorkSpace = Nothing
Set oUIDoc = Nothing
With Application
.CutCopyMode = False
.ScreenUpdating = True
'MsgBox stMsg, vbInformation
'Activate Lotus Notes.
AppActivate ("Notes")
Application.SendKeys "{Esc}"
Application.SendKeys "Y"
Application.SendKeys "{ENTER}"
Sheets("Launcher").Range("A5").Value = i + 1
thanks,
Rohit
