MACRO to send custom excel file via Outlook (with custom body)
gaurav99
Hi Everyone - I am trying to record a macro to send an excel file via outlook mail with custom data. Please suggest..
Many thanks in advance !!
(attached file for reference)
Mail body comprises of data present in excel file (data present in column N to Q - data is dynamic and is subject to change)
Mail subject: Counts of Name-- (ID:--) - Date:
Mail body :
Hi -
ABC (ID: ) did__100__ count on date
  • MACRO.xlsx
Hi Gaurav,
You can use something like the below.
Make sure you update the email id's and the subject accordingly. You could also find additional information here.
http://www.rondebruin.nl/win/s1/outlook/mail.htm
Sub Mail_Single_SendRequest()
'Working in 2000-2010
    Dim wb1 As Workbook
    Dim wb2 As Workbook
    Dim TempFilePath As String
    Dim TempFileName As String
    Dim FileExtStr As String
    Dim OutApp As Object
    Dim OutMail As Object
    Dim r As Integer, x As Double
    For r = 12 To 12 'data in row 12
    Dim strbody As String
    With Application
    .ScreenUpdating = False
    .EnableEvents = False
    Set wb1 = ActiveWorkbook
    If Val(Application.Version) >= 12 Then
        If wb1.FileFormat = 51 And wb1.HasVBProject = True Then
            MsgBox "There is VBA code in this xlsx file, there will" & vbNewLine & _
                   "be no VBA code in the file you send. Save the" & vbNewLine & _
                   "file first as xlsm and then try the macro again.", vbInformation
            Exit Sub
    With Application
    'Make a copy of the file/Open it/Mail it/Delete it
    'If you want to change the file name then change only TempFileName
    TempFilePath = Environ$("temp") & "\"
    TempFileName = wb1.Name & " " & Format(Now, "dd-mmm-yy h-mm-ss")
    FileExtStr = "." & LCase(Right(wb1.Name, _
                                   Len(wb1.Name) - InStrRev(wb1.Name, ".", , 1)))
    wb1.SaveCopyAs TempFilePath & TempFileName & FileExtStr
    Set wb2 = Workbooks.Open(TempFilePath & TempFileName & FileExtStr)
    strbody = "Dear " & "[name]," _
    & Chr(10) & Chr(10) & "[email subject]." _
    & Chr(10) & Chr(10) & "Best Regards," _
    & Chr(10) & Chr(10) & "[name]"
       ' Change the mail address and subject in the macro before
       ' running the procedure.
       'get the email address
    OutMail = Cells(r, 5)
    With OutMail
    .To = "[email id]"
    .CC = "[email id]"
    .BCC = ""
    .Subject = "[enter your subject]"
    .Body = strbody & .Body
    .Attachments.Add wb2.FullName
    'You can add other files also like this
    '.Attachments.Add ("C:\test.txt")
    .display   'or use .Display
    On Error GoTo 0
    wb2.Close SaveChanges:=False
    'Delete the file
    Kill TempFilePath & TempFileName & FileExtStr
    Set OutMail = Nothing
    Set OutApp = Nothing
    With Application
    .ScreenUpdating = True
    .EnableEvents = True
    Next r
Kind regards,
Anand
Thanks a lot Anand. This is on the lines I want. But can i request following changes to suggested solution.
1. File saving: I am planning to add the code to a read only template which would be 'saved as' particular name (as mentioned in cell M2, this is generated based on certain inputs) at a particular location (say desktop)
2. Mail body and Subject: I want to keep the mail body and subject dynamic by incorporating data in Row#1 of columns P to Column S
sample subject: Data for ABC (column P): ID: (column R): Dated (column Q)
Sample body: Hi All,
Mr. ABC did *********************** on Column Q
Desired: blah
Actual: Column S
3. And lastly: deleting everything except from data present in A:K range
Thanks a lot in advance and for your patience to read the above :)
  • Template.xlsm
Hey Anand - I was able to make the required changes. (code attached). Can you please guide to following last steps:
1. Change the temp file format to 'xlsx'. tried modifying the string function but getting error
2. Deleting Columns K to Column R from temp file.
3. removing the data in row 12 condition
many thanks
  Dim wb1 As Workbook
    Dim wb2 As Workbook
    With Application
            Exit Sub
    With Application
    TempFileName = ActiveWorkbook.Sheets("Details").Range("M2").Value
    strbody = "Hi " & "," _
    & Chr(10) & Chr(10) & ActiveWorkbook.Sheets("Details").Range("P1") & " - " & _
    ActiveWorkbook.Sheets("Details").Range("N2") & " - " & " " & _
    ActiveWorkbook.Sheets("Details").Range("N1") & "." _
    & Chr(10) & Chr(10) & "" _
    & Chr(10) & Chr(10) & "s " & "" & Format(ActiveWorkbook.Sheets("Details").Range("S1"), "Percent") _
    With OutMail
    .To = ""
    .CC = ""
    .BCC = ""
    .Subject = "Work " & " - " & ActiveWorkbook.Sheets("Details").Range("P1").Value & _
    " - " & ActiveWorkbook.Sheets("Details").Range("N2").Value & " - " & _
    ActiveWorkbook.Sheets("Details").Range("N1").Value
    On Error GoTo 0
    'Delete the file
    With Application
    Next r
