Macro to lock cells with column criteria
Hi Team,
Need help with a macro to lock cells based on the criteria of column header, for example in the attached file , i need all cells locked with column header "Texas" i.e, from column D,H,L,P,T,X from Row 7 to 32.
Thanks for your help.
  • TestLockcells.xlsx
Hi !​
According to your attachment a VBA starter demonstration :​
Sub Demo1()
           Dim Rg As Range, A$
    With Sheet1.UsedRange
          .Parent.Unprotect
          .Locked = False
           Set Rg = .Rows(1).Find("Texas")
        If Not Rg Is Nothing Then
           A = Rg.Address
            Do
              .Columns(Rg.Column).Locked = True
                   Set Rg = .Rows(1).FindNext(Rg)
            Loop Until Rg.Address = A
                   Set Rg = Nothing
          .Parent.Protect
