Macro issue
Dee
Hi guys,
In the below macro i am trying to copy the contents of one file to another file.Here i am trying to refer to the sheet and the column through input box and also the destination cells/column using input box.But getting error at referring destination cell.Can any one of you help me in this?
Thanking you in advance,
Dee
Sub Macro1()
Flatfilename = Application.GetOpenFilename(FileFilter:="Excel files (*.xls), *.xls", Title:="Please choose a file")
Filewithmacro = ThisWorkbook.Name
'thisworkbook is current book
'ftwbook is source file
Set ftwbook = Workbooks.Open(Filename:=Flatfilename, ReadOnly:=yes)
Set thiswbook = Workbooks(Filewithmacro)
Source = InputBox("Sheet name")
Set rngfind = Application.InputBox _
(Prompt:="Select the Range", Title:="Range Selecteren", Type:=8)
With rngfind
Selection.Copy
thiswbook.Worksheets("DFMA MAKE").Activate
'ActiveWindow.ScrollWorkbookTabs Position:=xlLast
'Sheets.Add After:=Sheets(Sheets.Count)
'Range("E1").Select
'cell = Application.InputBox("select the cell", Title:="cell", Type:=8).Select
'Selection.PasteSpecial Paste:=xlPasteValues, Operation:=xlNone, SkipBlanks _
:=False, Transpose:=False
ActiveSheet.Paste Destination:=Range("E2")
ftwbook.Activate
ActiveWindow.Close
Hui
Staff member
Dee,
The way you have written it the sheet "DFMA MAKE" must be in the workbook which has the Macro
is that what you wanted?
Dee
yes, exactly....
is there any other way(rewriting macro by taking any examle) to get what i wanted? pls suggest
Hui
Staff member
Dee
Have a look through
http://chandoo.org/forums/topic/need-macro-help
There should be enough there to help you out
