macro is not working
delta
Sheet name " Ledger "
contian
Col A : Party Names
Col B : Dates
Col C : Bill no
Col D : Bill Amount
userform name "Account_Ledger"
Comobbox1 = Party name
Textbox2 = Date
Textbox3 = Bill no
Textbox4 = Bill Amount
i would like when end date and party name is same then nothing , otherwise above macro is run
but given macor is add same end date and same party name.
why only second row of Sheet " Ledger " name e.g.(KALPESH PATEL) is not repeate
when i click ADD button then Below macro is run
>>> use code - tags <<<
Sub Add_Data()
Dim lastrow As Integer
Dim i As Integer
    lastrow = Sheets("Ledger").Cells(Rows.Count, 1).End(xlUp).Row + 1
    With Account_Ledger
                For i = 2 To lastrow
If Sheets("Ledger").Cells(i, 2).Value = CDate(.TextBox2.Value) And Sheets("Ledger").Cells(i, 1).Value = .ComboBox1.Text Then
       Exit Sub
        Sheets("Ledger").Cells(lastrow, 1) = .ComboBox1.Value                                    ' PARTY NAME
        Sheets("Ledger").Cells(lastrow, 2) = CDate(.TextBox2.Value)                              ' BILL DATE
        Sheets("Ledger").Cells(lastrow, 2).NumberFormat = ("dd/mm/yyyy")                         ' BILL DATE
        Sheets("Ledger").Cells(lastrow, 3) = .TextBox3.Value                                     ' BILL NO
        Sheets("Ledger").Cells(lastrow, 4) = Val(.TextBox4.Value)                                ' BILL AMOUNT
plse help
i attache sample file
rollis13
Have a try with these modifications to your macro:
Sub Add_Data()
    Dim i      As Integer
    With Account_Ledger
            If Sheets("Ledger").Cells(i, 2).Value = CDate(.TextBox2.Value) _
                MsgBox "Party/Date already present"     '<- added
                Exit Sub
            End If     '<- moved up
        Next i     '<-  moved up
