Macro help - code changes
Hi Guys - I have to summarize the data from multiple worksheets to one WS. I have the following code which create the summary sheet but need couple more changes highlighted in yellow, if you can help: Thanks
1554732287359-png.59332
  • Consol.xlsm
Clean code below. I have very simple requests to amend the code to include following 3 (highlighted in purple within the code)
' delete rows 1-5 in each worksheet
' only copy rows from the worksheets upto the month where column F or G has a value and ignore the rest
' copy formatting of existing sheets to summary sheet
    Public Sub CombineSheetsWithDifferentHeaders()
    Dim wksDst As Worksheet, wksSrc As Worksheet
    Dim lngIdx As Long, lngLastSrcColNum As Long, _
    lngFinalHeadersCounter As Long, lngFinalHeadersSize As Long, _
    lngLastSrcRowNum As Long, lngLastDstRowNum As Long
    Dim strColHeader As String
    Dim varColHeader As Variant
    Dim rngDst As Range, rngSrc As Range
    Dim dicFinalHeaders As Scripting.Dictionary
    Set dicFinalHeaders = New Scripting.Dictionary
    dicFinalHeaders.CompareMode = vbTextCompare
    lngFinalHeadersCounter = 1
    lngFinalHeadersSize = dicFinalHeaders.Count
Set wksDst = ThisWorkbook.Worksheets.Add
    For Each wksSrc In ThisWorkbook.Worksheets
    If wksSrc.Name <> wksDst.Name Then
    With wksSrc
    lngLastSrcColNum = LastOccupiedColNum(wksSrc)
    For lngIdx = 1 To lngLastSrcColNum
    strColHeader = Trim(CStr(.Cells(1, lngIdx)))
    If Not dicFinalHeaders.Exists(strColHeader) Then
    dicFinalHeaders.Add Key:=strColHeader, _
    Item:=lngFinalHeadersCounter
    lngFinalHeadersCounter = lngFinalHeadersCounter + 1
    Next lngIdx
    Next wksSrc
    For Each varColHeader In dicFinalHeaders.Keys
    wksDst.Cells(1, dicFinalHeaders(varColHeader)) = CStr(varColHeader)
    Next varColHeader
    ' only copy rows upto the month where column F or G has a value and ignore the rest
    With wksSrc
    lngLastSrcRowNum = LastOccupiedRowNum(wksSrc)
    lngLastDstRowNum = LastOccupiedRowNum(wksDst)
    Set rngDst = wksDst.Cells(lngLastDstRowNum + 1, _
    dicFinalHeaders(strColHeader))
    Set rngSrc = .Range(.Cells(2, lngIdx), _
    .Cells(lngLastSrcRowNum, lngIdx))
    rngSrc.Copy Destination:=rngDst
    Next lngIdx
    Next wksSrc
    MsgBox "Data combined!"
    Public Function LastOccupiedRowNum(Sheet As Worksheet) As Long
    Dim lng As Long
    If Application.WorksheetFunction.CountA(Sheet.Cells) <> 0 Then
    With Sheet
    lng = .Cells.Find(What:="*", _
    After:=.Range("A1"), _
    Lookat:=xlPart, _
    LookIn:=xlFormulas, _
    SearchOrder:=xlByRows, _
    SearchDirection:=xlPrevious, _
    MatchCase:=False).Row
    lng = 1
    LastOccupiedRowNum = lng
    End Function
    Public Function LastOccupiedColNum(Sheet As Worksheet) As Long
    Dim lng As Long
    With Sheet
    Lookat:=xlPart, _
    SearchOrder:=xlByColumns, _
    MatchCase:=False).Column
    lng = 1
    LastOccupiedColNum = lng
    End Function
