Macro Function to Capture Date for data entry in a cell
Dear All,
need urgent help, suppose I have a column(A) and whenever I enter a non -blank Value in the column(A1, A2 ...), the date must be captured in next column(B1, B2 ...).
Please note that this date must be locked and should not change when I refresh my file tomorrow or day after. For eg: If I made the entry on 1st Aug and do not change the value of the cell, my next column should continue showing 1st Aug whichever date I open the file. I tried below VBA Code but whenever I open the file, the column shows current date not the date at which I input the data. Please help
Function Timestamp(Reference As Range)
If Reference.Value <> "" Then
Timestamp = Format(Now, "dd-mm-yy")
Timestamp = ""
End Function
As an Example: I want to know whenever the line is approved: Whenever user puts OK in a cell, the next cell must thorugh the date at which OK was typed. The problem with above VBA is that everytime i reopen the file on other day, it gives todays date in nect cell using above function:(
Approval commnet When is this Approved?
OKApproval date
OKApproval date
OKApproval date
Marc L
'cause you use a formula … Instead you must use the Worksheet_Change event.​
You need further help ? So as per forum rules join at least a sample workbook in order to get a quicker & more targeted answer !​
@Marc Thanks for the hint. Please find attached the workbook
I am looking for capturing the approval date in column E2: E7 whenever OK is placed in D2:D7
I need to capture only the first date when OK was placed and should not refresh everyday
This date must be changed only when I am deleting D2:D7 value
Marc L
According to your attachment paste this code to the Sheet1 worksheet module :​
        If Target.CountLarge > 1 Then Exit Sub
    If Not Intersect([D2:D7], Target) Is Nothing Then
        If UCase(Target.Value2) = "OK" Then Target.Resize(, 2).Value = Array("OK", Date) Else Target(1, 2).ClearContents
    ElseIf Not Intersect([E2:E7], Target) Is Nothing Then
        Select Case Target(1, 0).Value2
               Case "OK": If Not IsDate(Target) Then Application.Undo
               Case Else: Target.ClearContents
        End Select
Thank you everyone for the help. You guys are awesome
I have used Now() function with iterative option kept on using circular reference. Is there any issue with this method? I am using a sharedrive excel for such approval whoch will be open and refreshed multiple times. But i have protected this formula
Formula logic is if date is non zero do nothing else paste NOW()
