Macro does not copy correctly
aleksandra123
Hi I have developed the below macro. The macro for the first part works perfectly. It fileter by column 6 and then copy and past to another sheet 3 columns. Then it come backs again filter by column 12 but then does not copy column 11 to Z column ( the rest is copied), when it comes back 3 time, filer by column 18 but still doesn copy column 17 to Z column and column 18 is copied as formula not value (wherease in first copy paste and second paste figures as value)
Could someone help me out? Probably loop would be better here but I would like to stay with this macro as I dont have too much time to rebuild everthing.
Sub CopyQ1()
Dim StartCell As Range
Dim StartCell2 As Range
Dim StartCell3 As Range
Dim StartCell4 As Range
Dim StartCell5 As Range
Dim StartCell6 As Range
Dim StartCell7 As Range
Dim StartCell8 As Range
Dim StartCell9 As Range
Dim LastRow As Long
Dim LastRow2 As Long
Dim LastRow3 As Long
Dim LastRow4 As Long
Dim LastRow5 As Long
Dim LastRow6 As Long
Dim DestLastRow As Long
Dim DestLastRow2 As Long
Dim DestLastRow3 As Long
Dim DestLastRow4 As Long
Dim DestLastRow5 As Long
Dim DestLastRow6 As Long
Sheets("xxx").Select
'filter the first  by the quater that it is required
      ActiveSheet.Range("$A$8:$AA$60000").AutoFilter Field:=6, Criteria1:="<>0"
'settings
Set StartCell = Range("A9")
Set StartCell2 = Range("E9")
Set StartCell3 = Range("F9")
Set sht = Worksheets("xxx")
Set sht2 = Worksheets("zzz")
'Find Last Row
  LastRow = sht.Cells(sht.Rows.Count, StartCell.Column).End(xlUp).Row
  LastRow2 = sht.Cells(sht.Rows.Count, StartCell2.Column).End(xlUp).Row
  LastRow3 = sht.Cells(sht.Rows.Count, StartCell3.Column).End(xlUp).Row
'Copy respective quater for the first and past into zzz file.
sht.Range(StartCell, sht.Cells(LastRow, 1)).Copy Destination:=sht2.Range("L4")
sht.Range(StartCell2, sht.Cells(LastRow2, 5)).Copy Destination:=sht2.Range("Z4")
sht.Range(StartCell3, sht.Cells(LastRow3, 6)).Copy Destination:=sht2.Range("V4")
'Come back to the xxx
'Unfilter
ActiveSheet.ShowAllData
'Filter the next  by the quater
      ActiveSheet.Range("$A$8:$AA$60000").AutoFilter Field:=12, Criteria1:="<>0"
'settings
   Set StartCell4 = Range("A9")
   Set StartCell5 = Range("K9")
   Set StartCell6 = Range("L9")
'Find Last Row and Column
  LastRow4 = sht.Cells(sht.Rows.Count, StartCell4.Column).End(xlUp).Row
  LastRow5 = sht.Cells(sht.Rows.Count, StartCell5.Column).End(xlUp).Row
  LastRow6 = sht.Cells(sht.Rows.Count, StartCell6.Column).End(xlUp).Row
  'Find the first empty row in columns in zzz file
  DestLastRow = sht2.Cells(sht2.Rows.Count, "L").End(xlUp).Offset(1).Row
  DestLastRow2 = sht2.Cells(sht2.Rows.Count, "Z").End(xlUp).Offset(1).Row
  DestLastRow3 = sht2.Cells(sht2.Rows.Count, "V").End(xlUp).Offset(1).Row
'Copy respective quater for the second  and past into zzz  file.
sht.Range(StartCell4, sht.Cells(LastRow4, 1)).Copy Destination:=sht2.Range("L" & DestLastRow)
sht.Range(StartCell5, sht.Cells(LastRow5, 11)).Copy Destination:=sht2.Range("Z" & DestLastRow2)
sht.Range(StartCell6, sht.Cells(LastRow6, 12)).Copy Destination:=sht2.Range("V" & DestLastRow3)
'Unfilter
      ActiveSheet.Range("$A$8:$AA$60000").AutoFilter Field:=18, Criteria1:="<>0"
'settings
   Set StartCell7 = Range("A9")
    Set StartCell8 = Range("Q9")
   Set StartCell9 = Range("R9")
  LastRow7 = sht.Cells(sht.Rows.Count, StartCell7.Column).End(xlUp).Row
  LastRow8 = sht.Cells(sht.Rows.Count, StartCell8.Column).End(xlUp).Row
  LastRow9 = sht.Cells(sht.Rows.Count, StartCell9.Column).End(xlUp).Row
  'Find the first empty row in columns in file
  DestLastRow4 = sht2.Cells(sht2.Rows.Count, "L").End(xlUp).Offset(1).Row
  DestLastRow5 = sht2.Cells(sht2.Rows.Count, "Z").End(xlUp).Offset(1).Row
  DestLastRow6 = sht2.Cells(sht2.Rows.Count, "V").End(xlUp).Offset(1).Row
sht.Range(StartCell7, sht.Cells(LastRow7, 1)).Copy Destination:=sht2.Range("L" & DestLastRow4)
sht.Range(StartCell8, sht.Cells(LastRow8, 17)).Copy Destination:=sht2.Range("Z" & DestLastRow5)
sht.Range(StartCell9, sht.Cells(LastRow9, 18)).Copy Destination:=sht2.Range("V" & DestLastRow6)
'come back to xxx and unfilter the table
RDAngelo
Possibly this will work...
Sub Not_Tested()
'!!! Test on a copy of your data !!!
    Dim ws1 As Worksheet, ws2 As Worksheet
    Dim lRow As Long
    Set ws1 = Worksheets("xxx")
    Set ws2 = Worksheets("zzz")
    With ws1.Cells(8, 1).CurrentRegion
        lRow = ws2.Cells(Rows.Count, 12).End(xlUp).Offset(1).Row
        .Offset(1).Columns(1).SpecialCells(xlCellTypeVisible).Copy ws2.Cells(lRow, 12)
        .Offset(1).Columns(5).SpecialCells(xlCellTypeVisible).Copy ws2.Cells(lRow, 26)
        .Offset(1).Columns(6).SpecialCells(xlCellTypeVisible).Copy ws2.Cells(lRow, 22)
        .Parent.ShowAllData
        .Offset(1).Columns(11).SpecialCells(xlCellTypeVisible).Copy ws2.Cells(lRow, 26)
        .Offset(1).Columns(12).SpecialCells(xlCellTypeVisible).Copy ws2.Cells(lRow, 22)
        .Parent.ShowAllData
        .Offset(1).Columns(17).SpecialCells(xlCellTypeVisible).Copy ws2.Cells(lRow, 26)
        .Offset(1).Columns(18).SpecialCells(xlCellTypeVisible).Copy ws2.Cells(lRow, 22)
        .Parent.ShowAllData
p45cal
Generally speaking, to copy values quickly, instead of your:
which copies everything including formulae, use the likes of:
With sht.Range(StartCell9, sht.Cells(LastRow9, 18))
  sht2.Range("V" & DestLastRow6).Resize(.Rows.Count, .Columns.Count).Value = .Value
