Hi All,
I'm not even a novice with VB let alone applying it to Excel, however I need to apply this to a Macro button to resolve an issue I have.
What I need to do is be able to set the maximum value of the X axis within the attached chart that resides in the 'Dashboard' tab. This should essentially reflect the value of cell D7 in the 'Summary' tab.
What I was hoping would work to do this is add a macro button (which I've added in cell D6 of the 'Dashboard' tab) that essentially sets the axis value for the stacked bar chart under it to the value of whatever is entered in D7 of the 'Summary' tab.
The code I have against this macro right now (that is not working) is as follows:
Any assistance would be greatly appreciated.
Thank you,
D1g.
Sub Set_Axis_Value()
' Set_Axis_Value Macro
' Sets the value to match the allocated budget
ActiveSheet.ChartObjects("Chart 21").Activate
ActiveChart.Axes(xlValue).Select
Sheets("Summary").Select
Range("D7").Select
Sub ScaleAxes()
With ActiveChart.Axes(xlCategory, xlPrimary)
.MaximumScale = Sheet3.Range("D7").Select
.MinimumScale = Range("D71").Select
With ActiveChart.Axes(xlValue, xlPrimary)
Thank you,
D1g.
