Looping macro help
harrisrs24370
Hello...can anyone help me figure out what I need to add to this macro in order to loop it across multiple worksheets? Here's my macro:
Sub CouponTest()
' CouponTest Macro
' Keyboard Shortcut: Ctrl+x
Sheets(Array("605", "606", "607", "608")).Select
Sheets("605").Activate
ActiveWindow.SmallScroll Down:=-9
Range("F13").Select
Sheets("605").Select
Range("D1").Select
ActiveWindow.SmallScroll Down:=162
Range("D166").Select
ActiveWindow.SmallScroll Down:=-183
Range("D1").Select
ActiveCell.FormulaR1C1 = "Desc"
Range("A1:H179").Select
ActiveWindow.SmallScroll Down:=-171
ActiveWorkbook.Worksheets("605").Sort.SortFields.Clear
ActiveWorkbook.Worksheets("605").Sort.SortFields.Add Key:=Range("D2:D179"), _
SortOn:=xlSortOnValues, Order:=xlAscending, DataOption:=xlSortNormal
With ActiveWorkbook.Worksheets("605").Sort
.SetRange Range("A1:H179")
.Header = xlYes
.MatchCase = False
.Orientation = xlTopToBottom
.SortMethod = xlPinYin
.Apply
ActiveWindow.SmallScroll Down:=-3
Range("A1").Select
Range(Selection, Selection.End(xlToRight)).Select
Selection.Subtotal GroupBy:=1, Function:=xlSum, TotalList:=Array(4), _
Replace:=True, PageBreaks:=False, SummaryBelowData:=True
ActiveWindow.SmallScroll Down:=-87
ActiveWindow.ScrollRow = 55
ActiveWindow.ScrollRow = 53
ActiveWindow.ScrollRow = 47
ActiveWindow.ScrollRow = 39
ActiveWindow.ScrollRow = 31
ActiveWindow.ScrollRow = 23
ActiveWindow.ScrollRow = 20
ActiveWindow.ScrollRow = 17
ActiveWindow.ScrollRow = 14
ActiveWindow.ScrollRow = 12
ActiveWindow.ScrollRow = 10
ActiveWindow.ScrollRow = 9
ActiveWindow.ScrollRow = 7
ActiveWindow.ScrollRow = 6
Range("D4").Select
Selection.Subtotal GroupBy:=4, Function:=xlSum, TotalList:=Array(8), _
Range("C11").Select
ActiveSheet.Outline.ShowLevels RowLevels:=2
Range("D48").Select
ActiveWindow.SmallScroll Down:=-21
Columns("A:C").Select
Range("C1").Activate
Selection.EntireColumn.Hidden = True
Columns("E:G").Select
Range("E2").Activate
Range("L26").Select
Columns("D:D").EntireColumn.AutoFit
Range("J58").Select
kchiba
Wrap the following around what you want to do.
Note you should clean up your macro by taking out all the code that reltaes to your moving around the sheets.
Dim xArray(4) '. number of sheets
xArray(1) = "605"
xArray(2) = "606"
xArray(3) = "607"
xArray(4) = "608"
For x = 1 To 4 ' number of sheets
Sheets(xArray(x)).Select
'YOUR CODE HERE
Next x
harrisrs24370
Thanks for your help. Please bare with me...I'm very new to macros. I included your commands, but when I run the macro it still only formats the first sheet ("605"). I'm sure there's something I've done wrong. Here's what I have now:
Sub CouponTest()
' CouponTest Macro
Dim xArray(4) '.number of sheets
xArray(1) = "605"
xArray(2) = "606"
xArray(3) = "607"
xArray(4) = "608"
For x = 1 To 4 'number of sheets
Range("F13").Select
Range("D1").Select
Range("D1").Select
.Header = xlYes
.MatchCase = False
.Apply
Range("A1").Select
Range("D4").Select
Range("C11").Select
Range("D48").Select
Range("L26").Select
Range("J58").Select
Next x
Hui
Staff member
Replace all
Sheets("605")
with
Sheets(xArray(x))
and
Worksheets("605")
with
Worksheets(xArray(x))
and delete the line
Luke M
harrisrs,
Not a direct answer to your first question, but a general tip on macro writing:
All of the ActiveWindow.ScrollRow lines can be deleted. That's simply telling the workbook to scroll to a certain row, which only affects visuals. It might actually make the user slightly dizzy watching all that.
Additionally, you should probably put the line:
At the beginning of your code. This tells XL to not update the screen until the code finishes. Benefits are no more "flashing screen", and code runs MUCH faster (sometimg 10x)
Hui
Staff member
So long as you put a
line at the end
Luke M
Hui,
While I admit it makes for "good" coding practice to reset the screenupdating at the end, is it really necessary? I've seen both methods used in coding, and it appears that the screen updating resets after the code has finished running.
Care to enlighten/teach on the issue?
