loop throw rows range values
Anilp29
I have an excel file which has several columns with headers such as name,year,country,organization. I want to loop through each row and send the value to pdf. I am using kofax PDF plus for this task. Below is the excel file format and code. The range value should be variable it should loop from second row as first row contains headers and pass data to PDF and save it by their first and last name.
Last NameFirst Name Organization track ID Country Year
ABC XYZ DL123 12345 USA 2019
TZY CVXAN156 12234 France 2015
ULO SXART990 65728 India 2018
>>> use code - tags <<<
Sub copytopdf()
    Dim strPDFPath              As String
    Dim objJSO                  As Object
    Dim strPDFOutPath           As String
    Dim PowerApp As App
    Dim PowerDVDoc As DVDoc
    Dim PowerDDDoc As DDDoc
    Dim jso As Object
    Dim wb As Workbook
    Dim Saveas As Variant
    Dim fdObj As Object
    Dim SavedFilePath As String
    Dim PDFPath As String
    Dim Path As String
    PDFPath = "C:\Users\anilpujar\Desktop\workdoc.pdf"
    Set PowerApp = CreateObject("NuancePDF.App")
    Set PowerDVDoc = CreateObject("NuancePDF.DVDoc")
    PowerDVDoc.Open (PDFPath)
    Set PowerDDDoc = PowerDVDoc.GetDDDoc
    Set jso = PowerDDDoc.GetJSObject
    jso.getField("Last Name").Value = Range("G2").Value
    jso.getField("First Name").Value = Range("F2").Value
    jso.getField("Country").Value = Range("M2").Value
    jso.getField("Year").Value = Range("N2").Value
    Path = "C:\Users\anilpujar\Desktop\"
    SavedFilePath = PowerDDDoc.Save(DDSaveFull, Path & Last Name & First Name & ".pdf")
