Locking a range of cells upon data entry
SUDESH123
Hi there, I am looking at a way on how to lock certain cells in a range after data entry in EXCEL. Before, the user can finalize their entry, there should be an option/message to prompt them to check their entry and inform them the cell will be locked. Can this be done in EXCEL VBA.
Thanks Sudesh.
What range of cells are you targeting and what is the name of sheet tab holding those cells ?
The following to be pasted into a Routine Module :
Sub DataChanes()
  Dim Msg As String, Title As String
  Dim Config As Integer, Ans As Integer
  Msg = "Are You Sure ?"
  Msg = Msg & vbNewLine & vbNewLine
  Msg = Msg & "Review your entries - Cells will be locked and changes cannot be undone." & vbCrLf & vbCrLf & _
              "Click YES to finalize your entries. Click NO to make changes."
  Title = "Data Changes"
  Config = vbYesNo + vbExclamation
  Ans = MsgBox(Msg, Config, Title)
  If Ans = vbYes Then
    CellProtect
  If Ans = vbNo Then Exit Sub
Sub CellProtect()
Dim Blatt As Worksheet, rng As Range
Set Blatt = Worksheets("Sheet1")
Set rng = Blatt.Range(Cells(1, 1), Cells(3, 7))
rng.Select
Blatt.Unprotect
Blatt.Cells.Locked = False
rng.Locked = True
Blatt.Protect
Sub CellUnProtect()
rng.Select
Blatt.Unprotect
rng.Locked = False
'Blatt.Protect
The above code focuses on range A1:G3 for locking and protection, on Sheet 1. The code can be edited to another range
and sheet if required.
  • Lock Cell Range.xlsb
Good morning, I have attached the file where the ranges need to be locked. These are on columns S, V, Y and AB. As soon as the user enters a "Yes" there should be a message that pops up to ask the user as to whether they want to finalise their entry. Once the entry is made the cell in that row should lock and only be allowed to open with a password. I hope this clarifies what I am looking at for assistance.
  • WP Test case progress update.xlsm
Paste the following in the CORE sheet module :
Option Compare Text
ActiveSheet.Unprotect
    If Intersect(Target, Range("S1:S200")) Is Nothing Then Exit Sub
        If Target = "Yes" Then
            Target.Offset(0, 3).Locked = True
            Target.Offset(0, 6).Locked = True
            Target.Offset(0, 9).Locked = True
            Target.Offset(0, 3).Locked = False
            Target.Offset(0, 6).Locked = False
            Target.Offset(0, 9).Locked = False
    ActiveSheet.Protect
