Lock folder using VBA
YasserKhalil
Hello everyone
I have found the following piece of code that is supposed to lock folder
Private Declare Function CreateFile Lib "kernel32" Alias "CreateFileA" (ByVal lpFileName As String, ByVal dwDesiredAccess As Long, ByVal dwShareMode As Long, ByVal PassZero As Long, ByVal dwCreationDisposition As Long, ByVal dwFlagsAndAttributes As Long, ByVal PassZero As Long) As Long
Private Declare Function CloseHandle Lib "kernel32" (ByVal hObject As Long) As Long
Private Declare Function ShellExecute Lib "shell32.dll" Alias "ShellExecuteA" (ByVal hWnd As Long, ByVal Operation As String, ByVal Filename As String, Optional ByVal Parameters As String, Optional ByVal Directory As String, Optional ByVal WindowStyle As Long = vbMinimizedFocus) As Long
Private Const GENERIC_ALL = &H1
Private Const OPEN_EXISTING = 3
Private Const FILE_FLAG_BACKUP_SEMANTICS = &H2000000
Sub Lock_Folder()
    Dim LockFolderPath As String, fHandle As Long
    LockFolderPath = ThisWorkbook.Path & "\TestFolder\"
    If LockFolderPath <> "" Then
        fHandle = CreateFile(LockFolderPath, GENERIC_ALL, ByVal 0&, ByVal 0&, OPEN_EXISTING, FILE_FLAG_BACKUP_SEMANTICS, ByVal 0&)
        ThisWorkbook.Sheets(1).Cells(1, 2) = fHandle
    MsgBox "Folder Locked...", 64
Sub Unlock_Folder()
    Dim fHandle As Long
    fHandle = ThisWorkbook.Sheets(1).Cells(1, 2)
    CloseHandle fHandle
I tested it but the folder is not locked .. it is still available
Any idea how to lock and unlock folder using VBA?
Just tested & Find working..
Sub Lock_Folder()
    LockFolderPath = ThisWorkbook.Path & "\TestFolder"
    If Dir(LockFolderPath, vbDirectory) <> "" Then
    'don't delete the such values from the cell
        MsgBox "No Such Folder Find", vbCritical
Sub Unlock_Folder()
    Dim fHandle As Long
    CloseHandle fHandle
  • Lock_a_folder.xlsm
Thanks a lot Mr. Deepak for reply and for test
I tested your file too but the same result .. I got the message "Folder Loked" but when trying to open the folder it opened ..it is not locked as supposed to be
Now it is working. I discovered that there was a space in the folder name .. and I was testing on the desktop directly
After moving the files to a new folder and removed the space it worked very well
But now there is an important question ..after locking and the excel file is open it is ok but after saving the excel file and trying to open the folder it is open and not locked ... Is this related to just the excel file open ...?
If so how can I lock the folder even after closing the workbook?!
Thanks change to this then work please tell me if User wise can we lock or give access from this code is this possible
means particular user open that folder then lock or particular user we give them access to this folder
please tell me
Private Declare PtrSafe Function CreateFile Lib "kernel32" Alias "CreateFileA" (ByVal lpFileName As String, ByVal dwDesiredAccess As Long, ByVal dwShareMode As Long, ByVal PassZero As Long, ByVal dwCreationDisposition As Long, ByVal dwFlagsAndAttributes As Long, ByVal PassZero As Long) As Long
Private Declare PtrSafe Function CloseHandle Lib "kernel32" (ByVal hObject As Long) As Long
Private Declare PtrSafe Function ShellExecute Lib "shell32.dll" Alias "ShellExecuteA" (ByVal hWnd As Long, ByVal Operation As String, ByVal Filename As String, Optional ByVal Parameters As String, Optional ByVal Directory As String, Optional ByVal WindowStyle As Long = vbMinimizedFocus) As Long
Here's another one!
with attached zip > unzip it & follow below!
Create a folder named Locker in same dire.
Copy-paste or create some stuff in that created folder named Locker.
Double click the locker.bat in the folder > Now it's locked+hidden.
To get it back..
Double click the locker.bat > Input deepak as password to unlock it.
Ref:
http://goo.gl/p2DECV
  • folder-locker.zip
Thank you very much Mr. Deepak ..
I know this way to lock folder .. I was searching for VBA method ..
Another point this method of using batch file is very easy to crack if you show hidden system files ...
Best regards
Nothing is unbreakable for advance user at all, VBA encryption is also breakable however this script can be manipulate to work with VBA.
What is the vbDirectory in that code. while i am debugging it comes up to "if " condition. Then directly it goes to the else condition.
Can you please check and assist on this earlier.
In my pc whle debugging vbDirectory shows as 16.
So what is that 16 means
balakrishna veerla
You should open a new thread
as written in Forum Rules, please reread
... I noticed that You done it,
but You didn't thread this to it.
