    Hi Guest,
    Yours,
    Chandoo
  2. Hi All
Lock and unlock cells based on condition
Discussion in 'Ask an Excel Question' started by rupal1234, Oct 22, 2018.
  1. rupal1234
    rupal1234 New Member
    27
    I want to give the user options which are conditional on another cell. For example, in cell B4 is a dropdown of numbers:If number is less than 12 than cell I4 will be grayed out, & be locked. And if number is greater than 12 than cell I4 will be unlocked
    I guess I have to do something in visual basic but I never used it before, so I would appreciate it if you could explain every single step [​IMG]
    I appreciate your help. Thanks!
  2. Belleke
    Belleke Active Member
    560
    Your file is missing.
  3. vletm
    vletm Excel Ninja
    4,918
    rupal1234
    hmm ... Cell i4 has a formula ...
    What would be Your idea of locking?
  4. rupal1234
    27
    i want to hide cell if i select number less than 12 based on dropdown than I4 should be locked and grayed out
  5. vletm
    vletm Excel Ninja
    4,918
    rupal1234
    'hide', 'locked and grayed out'
    ... would mean something like this ...
    Belleke likes this.
  6. rupal1234
    27
    unable to open up your attachment
  7. vletm
    vletm Excel Ninja
    4,918
    rupal1234
    Saved same file with other format...
    Can You open files which has marcos?
    rupal1234 likes this.
  8. Peter Bartholomew
    Peter Bartholomew Well-Known Member
    709
    I do not think locking is relevant to the problem you have described. That simply prevents the user from changing or overwriting your formula.
    In the attached I have conditionally formatted the cell so that zeros are greyed out and the number format either renders 0 as a blank or "N/A" meaning 'not available'.
    Sorry about changing your formulas to structured references; I have a blind spot when it comes to reading direct references - it is all a jumble of meaningless characters to me ;).
  9. rupal1234
    27
    Thankyou so much :)
  10. rupal1234
    27
    Thankyou so much :)
  11. rupal1234
    27
    Now If i select GI Round wire from dropdown G4 than it should locked and grayed out I4 and if i select GI Flat strip from dropdown G4 than it should locked and Grayed out H4
  12. Peter Bartholomew
    709
    @vletm
    You have done what the OP requested but I still struggle to see the point (by the way, I liked the ASE routine). Unlocking a formula cell achieves nothing of value whilst the formatting could equally be achieved using conditional formatting.
  13. rupal1234
    27
    Your code is working but now i want this functionality also but i dont know how to achieve this both
  14. vletm
    vletm Excel Ninja
    4,918
    rupal1234
    It would be ... to get needed parameters in one time.
    Even 'minor' change would mean a lot of changes...
    ... as You would notice.
    Peter Bartholomew
    True, sometimes 'the point' would be challenge to find out ...
    In this time, OP uses terms 'locked'
    ... so OP got 'locked' and that can use this way too.
  15. rupal1234
    27
    In this when i click on g4 and select ground wire than it should lock cell I4 and if i click on flat strip then it should hide H4
  16. vletm
    vletm Excel Ninja
    4,918
    rupal1234
    ... and if You click B4 any time and
    do or try to do selection
    ... what would happen or not?
  17. vletm
    vletm Excel Ninja
    4,918
    rupal1234
    This would have more clear rules ...
  18. rupal1234
    27
    This file is not opening
  19. vletm
    vletm Excel Ninja
    4,918
    rupal1234
    I tried to ask with Reply #7 something
    ... still waiting answer.
Share This Page
