Inventory solution
Mohandas
This file is for tracking the inventory for the manufactuing products
I have 3 sheets
1 RM (Raw Material)
2 PM (Packaging Material)
3 FM (Finished Material)
I have to select in the FM the raw material which is multiple may be more than 1 and pacaking material which also can be the multiple and the stock has to reduced in the concerned sheets
Any solution for this format
Please help
Mohandas
  • STOCK STATEMENT (1).xlsx
I have 3 sheets
1 RM (Raw Material)
Please help
Mohandas
I don't think you've made yourself clear as to what you need your spreadsheet to do. Please rephrase with what you are looking to accomplish. You may want to use specific sheet and cell references and show what the expected results you are looking for.
