Index help please! [SOLVED]
Hi
I have a problem here which im sure somebody will know the solution to:
http://i.imgur.com/WOgT9Hm.png
If you look at the image, amongst this table, there are different reference numbers. Two different letters get sent out amongst the same reference numbers - one in print and one in brail.
What i want to see, is what the last date that a letter was sent out for print, and for brail, but under a certain reference.
For example, i want to choose to look for reference A0002 want to know the last date that brail was sent out, and the last date that printed was sent out.
What I did was find the largest date amongst the table and returned its corresponding type and reference number, but I want to go back and start from the reference number, and work out what the last date was for brail and printed. I feel like i am nearly there but having a brain jam at the moment and cant work it out.
I then got this: =(INDEX($D$4:$D$28,(MATCH(G6,IF($B$4:$B$28=G7,$C$4:$C$28),0))))
This then returns the FIRST date rather than the last. How do I make it so that it picks up the last date?
EJ.
Thanks, EJ
With your data in B4:C19 excluding headers, use following formula:
=SUMPRODUCT(MAX((B4:B19="A00002")*(C4:C19="BRAIL")*(D4:D19)))
Hope that helps,
Search for Maxif in the Google Custom Search box at the top right of this page
Thanks for your help guys, I found the solution thanks to Hui's pointing in the right direction - answer lied in Maxif.
Thank you very much!
