increment value in same colmun using loop
delta
pls give me a code for vba for increment in value in same column. for your reference i attache the image file.
Right-click on the sheet concerned's tab and choose View code, then paste the following to where the cursor is flashing:
If Not Intersect(Target, Range("A2")) Is Nothing Then
  With Range("A3:A10")
    .FormulaR1C1 = "=R[-1]C*(1+6%)"
    .Value = .Value
Solution with 100% VBA
Sub Belle()
Dim cells As Range
    For Each cells In Range("A3:A10")
        cells.Value = cells.Offset(-1, 0).Value + cells.Offset(-1, 0).Value * 6 / 100
