Hi All,
I got an error message stating "Next Area" is not defined when I used the following codes.
If statement
code line 1
code line 2
GoTo Next Area 'so I want to ignore code line 3 and 4, go straight to Else then.
code line 3
code line 4
Next Area
Else Then
execute codes here
What is wrong with the codes above?
Also I have create a long table and there is mixed numbers and text in each cell. The numbers are associated to the cells numbers at the top of the sheet.
I need to update the numbers in the table. Is there a way to ask Excel to auto update the numbering in each cell instead of having me manually updating them?
If statement
code line 1
code line 2
code line 3
code line 4
Next Area
Else Then
execute codes here
