If Formula Required
Techtrend
HI Team
Details are mentioned in the attached document,
Need to filter stocks based on Signal change in C Col
Thanks in advance
Satish
  • FILTER-Zscore.xls
Hi to all,
Similar as LM solution but with normally entered:
=IFERROR(INDEX(A:A,AGGREGATE(15,6,1/($C$2:$C$100<>$F$2:$F$100)*ROW($C$2:$C$100),ROWS(C$2:C2))),"")
=IFERROR(INDEX(F:F,AGGREGATE(15,6,1/($C$2:$C$100<>$F$2:$F$100)*ROW($C$2:$C$100),ROWS(D$2:D2))),"")
Hi Neeraj,
You can understand the logic with this too:
=AGGREGATE(15,6,1/(CriteriaColumn=Criteria)*Values,1)
15 = function number i.e. SMALL
6 = used for ignoring error values
CriteriaColumn = Specify your criteria range, for example A2:A10
Criteria = Specify your criteria, for example single cell B2 or "abc" or range B2:B10
Values = Specify value range
1 at the last is used as K parameter, it can be replaced with ROW(A1) or ROWS(A$1:A1) so that it can be incremented +1 by dragging down.
Above aggregate function and LM's SMALL(IF(.....ROW( array produces same results.
See this link for ROW & COLUMN function:
https://www.myonlinetraininghub.com/excel-rows-and-columns-functions
HTH,
@Luke: It's great!! Sir, could you please explain this formula
Hi Neeraj, I notice you are asking to explain formulas once and a while. A good place to start with the basics is the Excel help, and you can always use the formula evaluation tool. Look for it in formula auditing on the formulas ribbon.
It explains step by step how Excel calculates and it shows for each argument the intermediate result. In Luke's formula the underlined part is the starting point. Press evaluate to see the step result and repeat. Besides being a nice too to help you debug your own formulas, you can also use it to understand the logic on how the formula is actually working. The preview window might be too small when dealing with large arrays, but still, I find it rather useful.
