Identifying changed data elements between same record on 2 files
TParsons
I’m looking for a solution re comparing data elements from within common records on 2 separate Excel files. For example, if the same person with same record ID appears on two files, but the second file’s record has a different mailing address, how do we identify the variance between the 2 files?
Here’s an example:
File 1 records
ID1000 John Smith 12 Main St Topeka KS 62000
ID1001 Tommy Shaw 11 Johnson Way Omaha NE 72331
ID1002 Bob Barker 154 Edgewood Ln Billings MT 89002
File 2 records
ID1001 Tommy Shaw 3445 Summerset Dr Omaha NE 72334
How do we compare files in this example to identify that Tommy Shaw has a different address on File 2 vs File 1?
Does anyone have formula or tips to handle this type of data comparison?
Thank you in advance.
TParsons
Based Your given information
=IF(a<>b,"DIFF","")
where a is file 1's cell and b is file 2's cell.
Only You know - what do You have in those files?
As a new member, please, reread Forum Rules
especially How to get the Best Results at Chandoo.org
... and You'll remember - what would You do next?
If your data is held in Tables and the IDs are reasonably reliable then
= OR( XLOOKUP(Table2[@ID],Table1[ID],Table1) <> Table2[@] )
will identify the cases in which the ID exists in the other table but with mismatched fields.
= SUM(SIGN(( XLOOKUP(Table1[@ID],Table2[ID],Table2) <> Table1[@] )))
would show the number of fields that differ.
TParsons
=IF(a<>b,"DIFF","")
Thanks, your answer seems to work and also directed me to some other relevant answers/Excel tools.
Thanks Peter, this should work!
