i need help with vba excel code for bring file's name from folder
mohamedtaha500
hello every one
i use this code to bring files's name have .doc from exact folder and subfolder from path which i put in code and put the data in excel sheet
the code is work great
but the problem is i need also date modified for every file but i can't edit on code
Sub ListAllFilesInAllFolders()
            ActiveSheet.DisplayPageBreaks = False
    Dim MyPath As String, MyFolderName As String, MyFileName As String
    Dim i As Integer, F As Boolean
    Dim objShell As Object, objFolder As Object, AllFolders As Object, AllFiles As Object
    Dim MySheet As Worksheet, rrr As Long
        lastrow = Sheet2.Range("a" & Rows.Count).End(xlUp).Row
        Sheet2.Range("a2", "a" & lastrow + 1).ClearContents
        MyPath = Sheet1.Cells(2, 1).Value & "\"
    Set objFolder = Nothing
    Set objShell = Nothing
    Set AllFolders = CreateObject("Scripting.Dictionary")
    Set AllFiles = CreateObject("Scripting.Dictionary")
    AllFolders.Add (MyPath), ""
    i = 0
    Do While i < AllFolders.Count
        Key = AllFolders.keys
        MyFolderName = Dir(Key(i), vbDirectory)
        Do While MyFolderName <> ""
            If MyFolderName <> "." And MyFolderName <> ".." Then
                If (GetAttr(Key(i) & MyFolderName) And vbDirectory) = vbDirectory Then
                    AllFolders.Add (Key(i) & MyFolderName & "\"), ""
            MyFolderName = Dir
        Loop
        i = i + 1
    Loop
    For Each Key In AllFolders.keys
        MyFileName = Dir(Key & "*.doc*")
        Do While MyFileName <> ""
            AllFiles.Add (Key & MyFileName), ""
            MyFileName = Dir
        Loop
    lastrow = Sheet2.Range("a" & Rows.Count).End(xlUp).Row + 1
    Sheet2.Cells(lastrow, 1).Resize(UBound(AllFiles.keys) + 1) = WorksheetFunction.Transpose(AllFiles.keys)
    Set AllFolders = Nothing
    Set AllFiles = Nothing
         ActiveSheet.DisplayPageBreaks = True
If I correctly understood your request, have a try with what I came up with:
    Dim i      As Integer
    Dim AllFolders As Object, AllFiles As Object
    Dim lastrow As Long, Key As Variant
    Dim FSO    As Object, AllDates As Object      '<- added
    Set FSO = CreateObject("Scripting.FileSystemObject") '<- added
    Set AllDates = CreateObject("Scripting.Dictionary") '<- added
    lastrow = Sheets(2).Range("A" & Rows.Count).End(xlUp).Row
    Sheets(2).Range("A2", "A" & lastrow + 1).ClearContents
    MyPath = Sheets(1).Cells(2, 1).Value & "\"
    i = 0
            MyFolderName = Dir
        Loop
        i = i + 1
    Loop
            AllDates.Add (Format(FSO.GetFile(Key & MyFileName).DateLastModified, "dd/mm/yyyy hh:mm:ss")), "" '<- added
            MyFileName = Dir
        Loop
    lastrow = Sheets(2).Range("A" & Rows.Count).End(xlUp).Row + 1
    Sheets(2).Cells(lastrow, 1).Resize(UBound(AllFiles.keys) + 1) = WorksheetFunction.Transpose(AllFiles.keys)
    Sheets(2).Cells(lastrow, 2).Resize(UBound(AllDates.keys) + 1) = WorksheetFunction.Transpose(AllDates.keys) '<- added
    Set FSO = Nothing                             '<- added
    Set AllDates = Nothing                        '<- added
    MsgBox "Done!"                                '<- added
    Dim i      As Integer
    i = 0
            MyFolderName = Dir
        Loop
        i = i + 1
    Loop
            MyFileName = Dir
        Loop
i'm sorry sir the code is not working
there is no debug but the excel file is freezing
also i try to open locals window and press f8 to figure out what happen but i think it's not working like i need
if you see the attachment you will know what i need the result of my code on coulmn a like photo
i need also date modified for each file on column b
if you see the attachment you will know what i need the result of my code on coulmn a like photo i need also date modified for each file on column b
This is what you should achieve with my edits. How many files do you plan to list? Test the macro in a new file and choose a folder with fewer files to list.
greet
now we took one step to forward
i edited some line about sheet name and my bath
and it seems start to work
but brought the date for first file only
i atteched photo for sheet
also photo for code locals window
it is seems the item for AllFiles is increase
but the item for AllDates in stop on one item
The error detection code is covering the reason. There is an issue in the code I used because when it finds the same date in different files it skips the output (On Error Resume Next). Update (open and save) the files without date in your list, launch the macro and you will see what I mean.
No idea why this happens, it's beyond my knowledge.
thanks very much sir
actually you help me to solve my problem
also i figured out what should to do
i will add one more properties to lastdatemodifed like name to get unique key depending on file name like this
AllDates.Add (Format(FSO.GetFile(Key & MyFileName).DateLastModified, "dd/mm/yyyy hh:mm:ss") & _
FSO.GetFile(Key & MyFileName).Name), ""
then i will split the text
thanks sir
I have found other file that error-out (for some reason) so your solution isn't resolutive. In case of error, instead of using On Error Resume Next, it would be best to fill the array AllDates with something like "Error Date" elsewise the array will have less items.
Have a try with this other approach with a 2-dimensional array instead of two arrays:
    Dim i      As Integer
    Dim FSO    As Object
    Dim AllFiles() As String
    ReDim AllFiles(0 To 1, 0 To 1)
    Sheets(2).Range("A2", "B" & lastrow + 1).ClearContents
    i = 0
            MyFolderName = Dir
        Loop
        i = i + 1
    Loop
    i = 0
            AllFiles(0, i) = Key & MyFileName
            AllFiles(1, i) = Format(FSO.GetFile(Key & MyFileName).DateLastModified, "dd/mm/yyyy hh:mm:ss")
            ReDim Preserve AllFiles(UBound(AllFiles), UBound(AllFiles) + i)
            i = i + 1
            MyFileName = Dir
        Loop
    For i = LBound(AllFiles, 1) To UBound(AllFiles, 2)
        Sheets(2).Cells(lastrow + i, 1) = AllFiles(0, i)
        Sheets(2).Cells(lastrow + i, 2) = AllFiles(1, i)
    MsgBox "Done!"
