HYPERLINK & INDEX
kkimiri
Kindly, how do i insert a link that returns the value of the clickable cell in another specific cell.
From the attached excel, on the Tab named Hyperlink, if i click on the hyperlinked cell H7 i want it to return the value MANAGEMENT on cell E5 (highlighted) and the same way if i click on H11 i want it to return the value OPERATIONS on cell E5 (highlighted).
(I want it to have the same functioning like INDEX function, on the Tab named index , i am able to have a drop down button that returns the value i select on the drop down on cell E2.)
Thanks and Kind Regards
chirayu
Assuming you mean clicking on Hyperlink updates the blue cell value? refer to below link
kkimiri
Thank You very Much. Appreciated.
Please is it possible to have the macro code as an excel formula.
