traehegdirb
in column A I have a list of numbers
in column B I have a formula which calculates the percent change in the numbers from one row to the next.
I want to then sort the resultant numbers in column B
Excel will not sort that list of results.
A B
[pre]
[/pre]
Column B2 will display the number -50
Column B3 will display the number 100
Column B4 will display the number 100
Column b5 will display the number -50
I now want to sort column B ascending
It should sort and display the following results in column B:
-50
-50
100
100
Instead, when I do the sort routine for column B, nothing changes in column B.
What Am I doing wrong?
A B
[pre]
2 16 =sum((A2-A1)/A1)*100
3 32 =sum((A3-A2)/A2)*100
4 64 =sum((A4-A3)/A3)*100
5 32 =sum((a5-a4)/a4)*100
-50
-50
100
100
